  • 1.  Missing "Origin" field/column in Advanced Find
    Posted Oct 21, 2022 05:20 PM
    We are on 2022  Wave 1 with "Modern" Advanced Find not turned on.
    When I do a new Advanced Find for Cases and try to add the Origin column to the view, it is not available under the Case entity/table.  If I select an existing Advanced Find and attempt to modify it, the Origin column is there and works fine.  I did a little poking around and found a new "Master Case" entity with an Origin column available, but when I add that to my find there is no data in the column.
    I entered a support case to Msft, and they suggested that I add the column to the App I am using.  When I attempt to do that, the column is not available to add.
    Any ideas as to what else I can try?  This almost seems like a "Modern Advanced Find" issue, but I've triple checked that it is not enabled in our tenant.  Screenshots below for clarity.
    Eva Sandvik
    Senior Access Control Analyst
    Sharp Community CONNECT
    San Diego CA
    D365 Online
  • 2.  RE: Missing "Origin" field/column in Advanced Find
    Posted Oct 23, 2022 01:53 AM
    Hi Eva,
    Have you checked if the field has been set to invisible?
    https://dynamics.mittermair.pro/2020/06/16/case-origin-not-visible-in-personnel-view/
    Also, I have just checked my environment with MAF disabled too and the column is available but my environment is running 2022 release wave 2 so it may have been inadvertently fixed by MS.
    Regards, Adam Travers
    Empath Services Ltd
    Southampton
