9.1 On Premise - Reports associated with Entities disappear
  • 1.  9.1 On Premise - Reports associated with Entities disappear
    Posted 2 days ago
    9.1 was recently released for version 9 on premise.   We loaded and discovered two problems.
    1. if you go to workspace / reports,  the edit button stopped working
    2. If you open an entity and click reports,  there are none listed to run
    3. if you are on a grid and you select some records and select reports,  none are listed.
    We opened a case with Microsoft support about it today.  Will be interesting to see what they find.  We got no errors loading the update and discovered this afterwards.
    Kevin Knorr
    IT Director
    MHG Services
    Fort Lauderdale FL
  • 2.  RE: 9.1 On Premise - Reports associated with Entities disappear
    Posted yesterday
    We found this error on the logs (xxxxxxx-Microsoft.Crm.Sandbox.WorkerProcess.log), it could be causing the issue, as can be seen below the failing query includes ReportServerUrl
    >Exception when executing query: SELECT Id, [ConnectionString], [DatabaseName], [ExternalSdkEndpoint], [HelpContentServerUrl], [InternalSdkEndpoint], [MirroredSqlServerName], [Name], [PartitionNumber], [PodId], [ProvisioningAffinityGroupId], [ProvisioningState], [ReportServerUrl], [ScaleGroupWebStoreName], [SqlServerName], [State], [StatsScaleGroupWebStoreName], [UniqueifierId], [WebApplicationUrl], [WebStoreName], [WitnessServerId] FROM [ScaleGroup] WHERE ((([Id] = @Id0)) ) Exception: Invalid object name 'ScaleGroup'. Exception: System.Data.SqlClient.SqlException: Invalid object name 'ScaleGroup'.
    Odin Bujeiro
    MHG Services
    Fort Lauderdale FL
