Odd view of activities in the new UUI
  • 1.  Odd view of activities in the new UUI
    Posted Oct 07, 2019 10:33 AM
    I am testing my final items in the new UUI and the view of "My Open Activities" shows a calendar view. Any ideas on how to get this back to a list view?  thanks, Laura
  • 2.  RE: Odd view of activities in the new UUI
    Posted Oct 07, 2019 05:22 PM
    Click on the ellipses (...) on the command bar, then click Show As, and then click Read Only Grid
    Highlighted Show As option on Command Bar
    Read Only Grid highlighted on Command Bar
    Ben Edgren
    CRM Applications Manager
    Hufcor, Inc
    Janesville WI
  • 3.  RE: Odd view of activities in the new UUI
    Posted Oct 07, 2019 07:20 PM
    @Laura Mortick - I would suggest you check the Activities entity. At the entity level, there should be a "Controls" tab ​ at the top. Check if the "Calendar Control" has been added. If so, you can specify if you want this used for "Web", "Phone", or "Tablet".
    ACE Microtechnology
  • 4.  RE: Odd view of activities in the new UUI
    Posted Oct 09, 2019 09:32 PM
    Thanks @Aaron Back - I just removed the calendar view in controls - thanks!​
    Also, @Ben Edgren - that did switch it back to the normal view.  How do i fix this for all users? I am not sure how it got set this way...
    thanks! Laura
  • 5.  RE: Odd view of activities in the new UUI
    Posted Oct 10, 2019 11:06 AM
    From what I have seen, that should not be the default view.  Do you have a group of test users that could log in while you look over their shoulder to see how it appears by default for them?
    Ben Edgren
    Hufcor, Inc
    Janesville WI
