  • 1.  How to Convert CSV to vCard for Free Online
    Posted Nov 09, 2021 06:41 AM
    CSV to vCard is a free contact file converter that can convert CSV contacts to vCard contacts. The procedure is simple: click the "Browse" button to select a contacts file (*.csv), the application will read all fields and data from the file, and then you must modify the vCard attribute for each CSV field. After you've filled in all of the required information, click "Convert" to generate a vCard file. The output file extension is *.vcf or *.vcard, and the default file extension is *.vcf, so you may think of this software as a CSV to vCard Converter.
    Furthermore, if all fields in your contacts CSV file are in English, the application will auto-fill correct vCard characteristics like First Name, Last Name, Job Title, and more. In addition, the software can automatically map various common fields to their corresponding vCard attributes (synonyms words), such as Family Name to Last Name, Occupation to Job Title, Web Page to Website, and so on.
    Please keep in mind that not all contact fields are supported; at the moment, the application only supports the most relevant fields. In addition, the resulting file is in vCard 3.0 (RFC 2425) format.
    https://www.arysontechnologies.com/csv-to-vcard/
    Mithilesh Tata
    01204541163
    Noida
  • 2.  RE: How to Convert CSV to vCard for Free Online
    Posted Nov 29, 2021 02:47 AM
    If you want to export CSV to VCF format then you can also take the help of  CSV to VCF Converter. This portable tool migrates single or multiple CSV file to VCF format with all mail and properties. User can export CSV to VCF.
    Xandra smith
    hjjkgui
