  • 1.  Split VCF File to Multiple VCF Contacts
    Posted Jul 07, 2021 04:17 AM
    This VCF Splitter is an efficient tool that split VCF file into multiple contacts in a quick way. It is specially designed with simple GUI in order to split multiple VCF into separate file format. This Split VCF File to Multiple VCF Contacts tool maintains the hierarchy by securing the original data from any loss or external sources. VCard splitter is well-suited with all recent and prior versions of Window.
    Related searches
    how to reduce vcf file size online
    split vcf file to multiple vcf contacts
    split vcf into multiple files online
    vcf splitter
    compress vcf file online
    extract vcf file online
    vcf file with multiple contacts
    Multiple VCF to single VCF online
    Split VCF into multiple files online
    Shayam Ram
    KNKTOOLS
  • 2.  RE: Split VCF File to Multiple VCF Contacts
    Posted Aug 18, 2021 05:01 AM
    If you want to split or merge your vCard (VCF) files then you should definitely go for vCard Splitter and Merger tool by DRS. This tool has the capability to add folders of vCard at once. It can convert single or multiple vCard files at once. You are provided with a feature to add a custom file location to your file. When it comes to data security it is a very reliable software. It is compatible with windows 10 and all the previous windows versions. You can download free demo version of the software from the official website for free and try your hands on the software.
    otis milburn
    otis milburn
    california CA
  • 3.  RE: Split VCF File to Multiple VCF Contacts
    Posted Oct 06, 2021 08:59 AM
    If you want to split vcf or vcard files into multiple contacts then you can use vCard Split and Merge tool. It successfully split your vCard files into multiple contacts on various criteria.
    Mithilesh Tata
    01204541163
    Noida
  • 4.  RE: Split VCF File to Multiple VCF Contacts
    Posted Nov 26, 2021 02:32 AM
    Multiple utility are available that divide large sized VCF files. Last time when I face this issue I used this tool VCF Split Tool to Split Large Sized VCF File Mailbox successfully. I recommend this tool because the result is very accurate.
    Visit at: https://www.osttopstapp.com/split-vcf.html
    Cooper smith
    hjjkgui
  • 5.  RE: Split VCF File to Multiple VCF Contacts
    Posted Dec 13, 2021 07:57 AM
    You can Split VCF File into Multiple VCF Contacts with the help of Cigati vCard Splitter Tool, one of the best software to split and merge the VCF file without losing any data.
    Chris Anderson
    Cigati Solution
    New York City NY
