  • 1.  How to Fix Outlook not syncing with Gmail?
    Posted Oct 13, 2021 03:52 AM
    If you are facing this issue where your Outlook not syncing with Gmail, then you need to understand the possible reasons that can cause this issue. I have recently, found this amazing write-up that explains the possible reasons behind this problem along with some manual ways to fix this issue. It can occur due to the following reasons:
    1. Due to the Windows update, this error seems to occur because it can block the IMAP Connection.
    2.  If your network connectivity is not strong then Outlook may not sync with Gmail properly.
    3. Due to the damaged or corrupted PST files.
    4. Inaccurate settings of your Google account.
    These are some main reasons that can cause trouble in syncing Outlook with your Gmail account. In this article, you can also find how you can fix this by executing the manual techniques. So, if you are facing this issue then you should go through this article. You will definitely find the solution to your query.
    Mike Foster
    Software Developer
    San Jose CA-95134, USA
  • 2.  RE: How to Fix Outlook not syncing with Gmail?
    Posted 8 days ago
    The contact list is a very important part of our personal life and our professional life. If you are facing a problem during Sync Outlook Contacts to Gmail then you can read the detailed information blog. The best methods are discussed for sync contact. As all the contacts of both the email clients are desired to be the same, users need to sync Outlook contacts with Gmail.
    Techie Techie
    Techer
