US - Texas - Houston - CRM
Case Record ID for Workflow
  • 1.  Case Record ID for Workflow
    Posted May 08, 2020 01:22 PM
    I am trying to create a survey through a workflow and I need to get Case record id.
    I downloaded this soultion but the record id is coming up as blank - https://github.com/demianrasko/Dynamics-365-Workflow-Tools/releases
    Is there a free solution or workflow or process that is available to get record if of a case that you guys are aware of?
    Please assist!
    Geethika L
  • 2.  RE: Case Record ID for Workflow
    Posted May 12, 2020 01:30 AM
    Do you want to create a survey or distribute a survey from a case? IF you have any trigger on the case record, we can use that in the workflow and case record id will be available in the workflow.
    Bala S
    Balachandar Swaminathan
    San Jose
  • 3.  RE: Case Record ID for Workflow
    Posted Jul 08, 2020 08:57 PM
    Hey @Geethika L,
    I know I'm a couple months late on this post. Are you still struggling with this? The GUID/unique ID of the case record will show up with the name ​'Case' in workflows and other processes.
    Let me know if you'd like any more help!
    Chad Althaus
    Bray International, Inc.
    Houston TX
  • 4.  RE: Case Record ID for Workflow
    Posted Jul 22, 2020 03:07 PM
    Edited by Geethika L Aug 12, 2020 11:59 AM
    I was able to get the GUID using this https://github.com/demianrasko/Dynamics-365-Workflow-Tools/tree/master/msdyncrmWorkflowTools
    Thank you.
    Geethika L
