inline image in Knowledge Article
  • 1.  inline image in Knowledge Article
    Posted Oct 03, 2019 03:56 PM
    I have CRM365 online, 9.1
    Users use Customer Service Hub to add Knowledge article. The challenge is that they can copy and paste images.
    example:
    Images wont show at all after save. I can add a web resource, then add image to it. But users wont have access to customization/web resource.
    Any thoughts?
    Mohamad Idlepi
    CRM Development Manager
    Cineplex Inc.
    Toronto ON
  • 2.  RE: inline image in Knowledge Article
    Posted Oct 04, 2019 03:41 AM
    Hi Mohamed,
    While reading your post i recalled a tip I had read on CRMTipoftheDay.
    https://crmtipoftheday.com/1254/design-dynamics-365-email-templates-with-the-new-email-editor/
    I think that in wave 2 this will be available to for copy paste.
    Alexandros Miaris
    CRM Consultant
    Dixons Carphone
    Peristeri
  • 3.  RE: inline image in Knowledge Article
    Posted Oct 08, 2019 01:43 PM
    Hello Alex
    Thank you for below ​answer
    But that applies for eMail template not Knowledge article
    Any more thoughts ?
    Mohamad Idlepi
    Cineplex Inc.
    Toronto ON
  • 4.  RE: inline image in Knowledge Article
    Posted Oct 15, 2019 01:39 PM
    Hi Mohamad,
    This was a source of frustration when we started to use Knowledge Articles. An inline image enhancement for Customer Service knowledge articles is planned for Wave 2, however is not in preview yet.
    What's new and planned for Dynamics 365 Customer Service
    We are holding off on using knowledge articles until this is available as the maintenance is too problematic, and we haven't found any workarounds.
    Marcus Cadena
    Crow Wing County
    Brainerd, Minnesota
  • 5.  RE: inline image in Knowledge Article
    Posted Nov 05, 2019 11:32 AM
    Edited by Sean O Malley Nov 05, 2019 11:32 AM
    Hi Mohamad,
    We were able to enable this and can now copy and paste images inline.
    1. We installed the "Customer Service Hub Anchor" solution for our environment via Dynamics 365 Administration Centre
    2. We then enabled inline images
             Open Customer Service Hub app
             Service Management
             Embedded Knowledge Search
             Set "Enable users to use the inline image feature when authoring  articles" to Yes
    Sean
    Sean O Malley
    AIG
  • 6.  RE: inline image in Knowledge Article
    Posted Nov 08, 2019 11:35 AM
    Sean,
    How is this working for you?  We read this article 2 days ago and found the solution in our port but now it has disappeared before we've had a chance to test.  As mentioned by another user, not having images has stopped our rollout of KB.  We've tried using Sharepoint but continuously have issues with authentication.
    Tammie
    Tammie Viot
    Business Architect
    Command Alkon Incorporated
    Birmingham AL
  • 7.  RE: inline image in Knowledge Article
    Posted Nov 11, 2019 03:49 AM
    Hi Tammie,
    It's working as planned in Unified Interface. We just had to update some security roles to allow read access to Knowledge Article Images.
    I'd advise opening a support ticket with MS if the solution is no longer available.
    Sean
    Sean O Malley
    AIG
  • 8.  RE: inline image in Knowledge Article
    Posted Mar 21, 2020 05:46 AM
    Edited by Balachandar Swaminathan Mar 21, 2020 05:46 AM
    Hi All,
    I'm trying to enable inline image ability in Knwoeldge management in D365 crm v9.1 But the setting is missing in our prod environment but is available in a lower environment. I have installed the CSH Anchor solution in prod but the weird thing is its nto even installed in our qa instance but the setting shows up.
    Any thoughts? In another dev instance, I installed the anchor solution and enabled this setting and inline images work but when I try to access that setting it doesn't show up.Very weird...
    San Jose
  • 9.  RE: inline image in Knowledge Article
    Posted Jun 03, 2020 11:00 AM
    This started to work automatically after the upgrade to April 2020 release.
    San Jose
