Annoying and bemusing Jscript error
  • 1.  Annoying and bemusing Jscript error
    Posted Jul 03, 2019 11:52 AM
    I'm getting the JScript error "TypeError: Cannot read property 'getFormContext' of undefined" for this code:
    var Sdk = window.Sdk || {};
    (function () {
        // Code to run in the form OnSave event
        this.formOnSave = function (executionContext) {
            var selectedOptionText = formContext.getAttribute("new_bookingservicetasks").getText();
    	        var textfield = formContext.getAttribute("new_servicetasknotes");
    		var arrayLength = selectedOptionText.length;
    		var concatenatedText = "";
    		for (var i = 0; i < arrayLength; i++) {
    			concatenatedText += selectedOptionText[i] + "; ";
    	textfield.setValue(concatenatedText);
    }).call(Sdk);
    I've passed the execution context as the first parameter:
    I've published all customizations lots of times and, tried a different browser.  The most bemusing thing is that the script works, I just get a popup script error!
    Any thoughts?
    Stewart
    Stewart Tranter
    Business Systems Manager
    TCL Group
    Derbyshire, UK
  • 2.  RE: Annoying and bemusing Jscript error
    Posted Jul 03, 2019 02:14 PM
    Try passing the context as parameter to the main function.
    Sunil Raheja
    Aha Apps
    Glen Allen VA
  • 3.  RE: Annoying and bemusing Jscript error
    Posted Jul 04, 2019 04:40 AM
    Hi Sunil,
    Thanks for your reply.  I'm not quite sure how this would look.  I've tried:
    (function (executionContext) {
        this.formOnSave = function (formContext) {
    }).call(Sdk);​​
    and now it doesn't work at all.
    Stewart
    Stewart Tranter
    TCL Group
    Derbyshire, UK
  • 4.  RE: Annoying and bemusing Jscript error
    Posted Jul 05, 2019 08:30 AM
    Well, I've fixed it.  Not quite sure how, but I am now using the onFormChange event to call this script:
    (function () {
        // Define some global variables
        // Code to run in the attribute OnChange event
        this.attributeOnChange = function (executionContext) {
                	var textfield = formContext.getAttribute("new_bookingservicetasktextfield");
    			concatenatedText += selectedOptionText[i] + ";";
    }).call(Sdk);​
    It works beautifully.  Every time a value is added or removed, from the multi-select option set, the text field updates with the chosen values.
    Stewart
    Stewart Tranter
    TCL Group
    Derbyshire, UK
  • 5.  RE: Annoying and bemusing Jscript error
    Posted Jul 05, 2019 10:35 PM
    Apologies for not looking at this earlier Stewart.
    And am glad it worked finally. I did not pay attention that you were not calling it on Attribute's on change event, which is how it should have been. Great work!!
    Sunil Raheja
    Aha Apps
    Glen Allen VA
