Hello Geoff,
Thank you for your response. Below are screenshots of me accessing my solutions with each method:
D365 UI:
PowerApps UI:
Sorry to be a pain, I am worried the classic view is soon to be gotten rid of so I am trying to get in as much practice as I can in the PowerApps side of the UI. As you can see, the solution "Opportunity Parent" is available in the classic view, but not in the PowerApps area. I am in the same environment. I have reviewed my rights and I do believe I have all that are necessary. I appreciate any insight I can get!
Corinne Perry
A360 Sheet Metal Products
Vancouver
Sent: Apr 22, 2020 09:30 AM
Subject: Customizing Dynamics with PowerApps
Hi Corinne,
Your old solutions and customizations should still be available (assuming you have permission to see them). You can access them from either the D365 interface, or through Power Apps. Here's how.
Accessing Solutions Thru the D365 UI
- Log into D365
- From any location in D365 (modern UI), click the "gear" icon in the upper right
- Select Advanced Settings
- You are now on the legacy user interface, but with access only to the Settings area.
- Navigate to Solutions.
- You should see all active solutions in this location.
Accessing Solutions Thru the Power Apps UI
- Log into Power Apps (make.powerapps.com)
- In the upper-right corner, make sure your environment is set correctly (this may be why you didn't see them)
- Click Solutions and you should see your solution
- If you are here and you want to see your solutions the old way, click "Switch to Classic"
Geoff Ables
Managing Partner
C5 Insight
Charlotte NC
Sent: Apr 21, 2020 10:51 AM
Good morning,
I wanted to inquire with other Dynamics users and see if you guys were running in to the same issue. Now that the method of customization is completely moving to the PowerApps platform, I can no longer see the main custom solution I had been working on that was actively affecting our CRM. It appears that the solution is still running, as the custom fields that were a part of that solution are still showing and usable, but I cannot seem to access or find it the solution to make any additional edits. Is data still being moved or is this something I need to inquire with Microsoft about further?
Corinne Perry
Vancouver, WA
