Sample Data Installed
  • 1.  Sample Data Installed
    Posted Jul 11, 2019 10:24 AM
    Yesterday, I copied the prod customization instead of a full copy to my DEV environment.  then I tried to install the sample data.  I looked an there is not sample data to be found yet the Data Management>Sample Data has it as installed.
    Any thoughts?  is the load sample data no longer functional?
    Jill Vari
    Dynamics 365 CRM Admin/Developer
    Servicelink
    Moon Township PA
  • 2.  RE: Sample Data Installed
    Posted Jul 11, 2019 10:43 AM
    Check Settings, Data Management, Imports and see if there were errors.  You should see a whole slew of import jobs there.
    Good luck!
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
  • 3.  RE: Sample Data Installed
    Posted Jul 12, 2019 08:20 AM
    I opened a ticket with Microsoft two days ago on this very issue. Our environments show "Sample Data is currently being installed/removed. Only one install/remove operation is allowed at a time." Therefore, I have assumed the imports have started, but no data ever populates. To @Chris Harrington's good recommendation, I don't have import records to check for errors. This lack of records would lead me to believe that the imports didn't begin.
    I'll keep this thread updated with any progress or more likely the poor excuse and dreaded "by design" response.
    Patrick Wright, MCSE
    Senior CRM Administrator
    Cherry Bekaert LLP
    Richmond VA
  • 4.  RE: Sample Data Installed
    Posted Jul 12, 2019 09:28 AM
    When I looked at the process report on the imports it was cancelled.  The error had something to do with background processes being deactivated.  I will also put in a support request with Microsoft. Thanks for your input.
    Jill L. Vari
    CRM Administrator, Sales Support and Analytics
    O: 412-776-1611
    M: 412-352-8059
    Jill.vari@svclnk.com
    1200 Cherrington Pkwy, Moon Township, PA 15108
    image003.png@01D33B66.59E550E0
    NOTICE: The information contained in this message is proprietary and/or confidential and may be privileged. If you are not the intended recipient of this communication, you are hereby notified to: (i) delete the message and all copies; (ii) do not disclose, distribute or use the message in any manner; and (iii) notify the sender immediately.
  • 5.  RE: Sample Data Installed
    Posted Jul 12, 2019 09:29 AM
    Jill Vari
    Servicelink
    Moon Township PA
