Creating a View with Top 100 Records
  • 1.  Creating a View with Top 100 Records
    Posted Jul 28, 2020 01:47 PM
    I may be missing something obvious, but is there a way to create views that show just the top 50 or top 100 records based on estimated revenue? It seems so simple, but I can't seem to find a way to limit the number of records to show in a view based on a count. Please don't laugh at me if I'm missing the obvious. Any help would be greatly appreciated.
    Scott Grimes
    ITW / Hobart
    Troy OH
  • 2.  RE: Creating a View with Top 100 Records
    Posted Jul 28, 2020 03:38 PM
    Scott,
    If you have access to XrmToolbox, a quick way to accomplish this is with Jonas Rapp's FetchXML Builder tool. You can create a simple advanced find query in CRM for the entity you want such as opportunity. Include the columns you want and save it. Then, in XrmToolbox open the query in the FetchXML builder. In the left pane in the Node Properties there is a top property. If you type in 50 or 100 there, it will modify the fetch xml to limit the results. You can then save it back to CRM either with the same name or a new name.
    There are some other ways I've seen to do this, but this is probably one of the fastest and easiest ways to modify an advanced find view in ways that you can't in the CE designer.
    I have attached a screen shot of an example.
    Andy Arndt
    Minitab, Inc.
    State College PA
  • 3.  RE: Creating a View with Top 100 Records
    Posted Jul 28, 2020 05:05 PM
    Andy,
    Thank you so much for your reply. I used the FetchXML Builder tool in the XRMToolbox to build my query as you described, but how do I then get that query into a view in CRM? I couldn't find a way to build the view using XML or import the XML file.
    Scott
    Scott Grimes
    ITW / Hobart
    Troy OH
  • 4.  RE: Creating a View with Top 100 Records
    Posted Jul 29, 2020 12:30 AM
    You can use View Designer plugin from xrmtoolbox to update view fetchxml.
    https://www.arbelatech.com/insights/blog/creating-system-views-with-complex-not-in-filter-in-dynamics-365-for-customer-engagement.html
    If found helpful, Please mark my answer verified.
    Bipin Kumar
    Avanade
    Hyderabad
  • 5.  RE: Creating a View with Top 100 Records
    Posted Jul 29, 2020 08:26 AM
    I hadn't tested this end to end before posting my original suggestion, but I knew it worked in FetchXML Builder to limit the results. As Jan Van Haver posted I thought I just needed to save it back to CRM. When I did that and closed and re-opened FetchXML Builder and re-opened the query, it retained the top clause in the FetchXML. However, it seems like the Advanced Find code in CE v9 online does not read the top clause correctly. The results are not limited when I run the query in Advanced Find. Also, when I choose download FetchXML in Advanced Find, the top clause is not there. When I open the query in XrmToolbox FetchXML Builder, it's there, but not when opened from within CRM. I think it's saving the full query definition including the top clause to the SavedQuery table in CRM, but Advanced Find is ignoring that part of it.
    Andy Arndt
    Minitab, Inc.
    State College PA
  • 6.  RE: Creating a View with Top 100 Records
    Posted Jul 29, 2020 02:53 AM
    Edited by Jan Van Haver Jul 29, 2020 02:54 AM
    Scott, it's easier that what you might already have tried: create a view fitting your needs in D365, open FetchXML Builder, then open that view there an click the top node "fetch" (in the top left area). In the first field under Node Properties (bottom left area), enter the number you want (e.g. 50) and then simply save the view using the Save menu options in FetchXML Builder.
    The updated view is then available in D365 right away.
    Jan Van Haver
    G Data CyberDefense AG
    Bochum
  • 7.  RE: Creating a View with Top 100 Records
    Posted Jul 29, 2020 04:57 PM
    Thank you so much for your suggestion. I did as you suggested, creating a view in D365 that was what I needed, then opened it in FetchXML Builder and entered 100 in the first field under Node Properties. I then executed it in FetchXML Builder and it ran fine and returned only the 100 records that I wanted. I then saved it to  D365 from FetchXML Builder. However, when I go into D365 and bring up the view, I get an Invalid Argument error (see the screen shot attached). Any ideas or suggestions?
    Scott Grimes
    ITW / Hobart
    Troy OH
    Attachment(s)
  • 8.  RE: Creating a View with Top 100 Records
    Posted Jul 30, 2020 03:07 AM
    Hmm, it might then be different in different versions, Scott. We are currenly using 8.2 On Prem, and I guess your are using the online version? I hope another community member with Online could test this too.
    Jan Van Haver
    Bochum
  • 9.  RE: Creating a View with Top 100 Records
    Posted Jul 30, 2020 08:11 AM
    I have tested a few scenarios and I get different outcomes. Our org hasn't been transitioned yet to Unified Interface (UCI) only, but we are using a Model Driven app to access CE in the UCI as well as still using classic for some things. I noticed that the changes made for the top clause in FetchXMLBuilder are being saved in the query, but various places in CRM interpret it differently. We are online with the latest North America service update for v9. 2020 Release Wave 2 is applied. Here are the different outcomes.
    1. Run the query in FetchXML Builder: returns 100 records (expected result)
    2. In the classic interface, select the Opportunity entity and select the view and it returns 100 records (expected result)
    3. In the UCI, select the Opportunity entity and select the view and it displays the "Invalid Argument" error that Scott attached.
    4. Run advanced find from the classic interface and it returns all records, not limited to 100, but no error.
    5. Run advanced find from the UCI and it returns all records, not limited to 100, but no error.
    This makes me think that the internal code that processes queries and returns results is a little different for Advanced Find vs. when the view is selected from the home screen of an entity. Also, it appears that the UCI has some slightly different code than classic for presenting views from the home screen of an entity.
    This seems like a good candidate for a support case to find out if this is a bug or by design.
    Andy Arndt
    Minitab, Inc.
    State College PA
  • 10.  RE: Creating a View with Top 100 Records
    Posted Jul 30, 2020 04:39 PM
    Thanks everyone for the great ideas, suggestions, and help. As Andy suggested, we're going to submit this as a support case. If I get any additional information, I will post here for everyone to see.
    Thanks again!
    Scott Grimes
    ITW / Hobart
    Troy OH
  • 11.  RE: Creating a View with Top 100 Records
    Posted Jul 31, 2020 04:48 AM
    Been interesting to follow this thread, and I only want to add my support to opening a support case with Microsoft and highlighting the different behavior regarding "top" that @Andy Arndt found. The UCI team loves getting that kind of feedback :)​
    Jonas Rapp
    MVP
    Sweden
  • 12.  RE: Creating a View with Top 100 Records
    Posted Aug 11, 2020 01:28 PM
    Edited by Scott Grimes Aug 11, 2020 01:29 PM
    Just wanted to post an update for anyone who may have been following or interested in this post. We put a case in with Microsoft, and were told that the "Top" clause is not supported in CRM online (see screen shot below). They suggested that I try using the "Count" clause, and when I tried that, all it did was limit the number of records that displayed per page, not the total number of records that displayed on the view. I just got off a Teams call with Microsoft, and according to the person I was talking with, the only way to limit the total number of records you display on a view is by using filters. There is no way to limit a view to an exact number of records, such as the top 25 or top 100. Very disappointed. Can't understand why the "Top" clause wouldn't work.
    Oh well, on to the next problem. Thanks again to everyone who offered advice and suggestions.
    Scott Grimes
    ITW / Hobart
    Troy OH
  • 13.  RE: Creating a View with Top 100 Records
    Posted Aug 13, 2020 05:22 AM
    The schema definition for FetchXML for Power Apps / Common Data Service clearly states the "top" attribute being supported...
    https://docs.microsoft.com/en-us/powerapps/developer/common-data-service/fetchxml-schema
    Maybe the support engineer should be informed about this...
    Best.
    Jonas
    Jonas Rapp
    MVP
    Sweden
