  • 1.  Unified Interface Issue
    Posted Oct 16, 2019 04:25 PM
    Even after changing the setting on the sandbox Admin center I only get Unified Interface initially but as soon as I select solution everything turns back to classic view.
    So there must be some additional steps which we have to do at our end to make everything Unified Interface view. I Followed below
    link https://docs.microsoft.com/en-us/power-platform/admin/enable-unified-interface-only.
    Anybody know if I missed anything here?
    Regards
    Jeebo Mathews
    Agricorp
  • 2.  RE: Unified Interface Issue
    Posted Oct 16, 2019 05:22 PM
    Hi @Jeebo Mathews,
    I am not sure that I understand well the issue you have. Yet, here is a few hints :
    ​​- When unified Interface is activated, Advanced settings (such as solutions, administration, Security, ...) stay on the classic interface (this will progressively be migrated to powrapps admin portal i guess). So this may explain why you go back to classic UI when clicking on solutions
    - For your users to use the Unified Interface, you need to provide them a Model driven app made for unified interface. Should be ok if you use the last version of sales app for exemple. But if you use "Dynamics 365 - custom", there will be issues.
    Best regards,
    Laurent Maneville
    Nmédia
    Drummondville QC
  • 3.  RE: Unified Interface Issue
    Posted Oct 17, 2019 01:48 PM
    HI Laurent,
    I am trying to show our solution with all the list of processes including the workflows, business process flow, actions in Unified Interface to someone now it seems every time I open the solution it by default opens in the legacy Web ​interface rather than the Unified Interface.
    Jeebo Mathews
    Agricorp
  • 4.  RE: Unified Interface Issue
    Posted Oct 17, 2019 02:00 PM
    Hi Jeebo,
    When I open the solution, it appears by default on the Unified interface. But this is rather new... I have this behaviour since begining of october, before it was opening the old interface even if Unified Interface was activated. Moreover, I think that the new UI is not perfect for managing solutions... so I think that this is still in development from Microsoft and I am not surprise that you are still on the old interface for solutions. The important is that unified interface is activated for users when going to leads, opportunities, accounts, ...
    Laurent Maneville
    Nmédia
    Drummondville QC
  • 5.  RE: Unified Interface Issue
    Posted Oct 17, 2019 03:30 PM
    @Jeebo Mathews - There is a setting under the Settings/Administration/System Settings. This will force the new Unified Interface as the default. Also, you can "turn off" the access to the classic by setting the option to "No". (see below)
    ACE Microtechnology
