Currency lookup not showing results based on Currency Code
  • 1.  Currency lookup not showing results based on Currency Code
    Posted Nov 08, 2019 04:19 AM
    We're having some issues with the currency lookup across forms in the system.
    Our Currency Lookup View looks like this and includes the Currency name and Currency Code columns:
    However, when searching for the Currency Code in the lookup field, e.g. USD, nothing is returned.
    What is really weird is, that it seems to be matching the "U" and "S" - but when the "D" is entered there's no match 🤯
    This is working fine for all other lookups in the system, where we are using other columns. E.g. for user lookup, it is possible to search for initials as that column is included in the lookup view. Moreover, I know that this has been working fine previously.
    Is anyone else having this issue?
    #Functional
  • 2.  RE: Currency lookup not showing results based on Currency Code
    Posted Nov 08, 2019 08:37 AM
    I just tested and saw the same behavior.  I looked at the Quick Find view for the Currency entity and the Currency Code was not set as a quick find field so I set it as one and then the search for USD worked as expected.
  • 3.  RE: Currency lookup not showing results based on Currency Code
    Posted Nov 08, 2019 08:52 AM
    Awesome. I guess Microsoft has changed how it works recently.
    Thanks @Jill Vazquez
