Lookup vs.. Add new record on Custom entity
  • 1.  Lookup vs.. Add new record on Custom entity
    Posted Oct 03, 2019 12:33 PM
    Hello.
    I have a custom entity. On it, I have a subgrid of that same record type to build a parental view. When I click the "+" to search for an existing record, it opens a new form to add a new type of that record. I would like it instead to open the in-line lookup so I can add an already-existing record. I have seen some information on how to do this with differing record types, but have been unable to find out what I am missing when it is the same entity type.
    How can I get it so it gives me a lookup and not try to enter a new record?
    If you need more details, let me know.
    Joe Vekich
    SICK, Inc.
    Bloomington MN
  • 2.  RE: Lookup vs.. Add new record on Custom entity
    Posted Oct 04, 2019 09:02 AM
    The '+' button on a subgrid is strictly for new records, not for adding existing records.  To add an existing record, you would need to navigate to the 'Related' area where you should be able to find the 'Add Existing' button.
    Hope this helps!
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
  • 3.  RE: Lookup vs.. Add new record on Custom entity
    Posted Oct 04, 2019 10:08 AM
    Thanks, Chris -
    However, I do get this functionality on a different subgrid.
    "Account Conditions" is an entity that is N:1 to Accounts. I found that is I make the "Account" field required on the Account Condition, I got the "New" screen. If it is not required, I get the Lookup.
    So, in this case, I am adding the same record type: "Global Account Data". There is a "Parent Global Account Data" field that feeds this subgrid, and it is not required like my previous example. I would think that means I get the Lookup, not the "New" screen.
    Basically, I followed what I read in this post, but it does not seem to apply if the subgrid is the same record type:
    https://www.crmug.com/communities/community-home/digestviewer/viewthread?MessageKey=fd9a4ad1-1850-481b-bac7-e4a63be36056&CommunityKey=dc83c23b-ede0-4070-ae7a-dd90859148a6&tab=digestviewer
    Joe Vekich
    SICK, Inc.
    Bloomington MN
  • 4.  RE: Lookup vs.. Add new record on Custom entity
    Posted Oct 04, 2019 11:09 AM
    Ok, I think I misunderstood then.  You may be correct that adding something from the same entity won't work. You'd have to go to the 'target' child record, and set the parent there.
    Good Luck!
    Chris Harrington
    Solutions Architect
