Missing privilege for editable grids
  • 1.  Missing privilege for editable grids
    Posted Jul 24, 2020 04:20 PM
    We have activated the control fro editable grids and subgrids in Dynamics 365 Customer Engagement. The issue we realized is that admin can use the editable grid but the security roles we limited for the users cannot.
    The custom enittity tab for the entity the users have create, read, write, append and append to. Which tab and function in the security should we set up for end users to be able to benefit from the editable grids?
    #CustomerEngagement #FieldService
    Sharee Anderson
    Vertex Aerospace
    Madison
  • 2.  RE: Missing privilege for editable grids
    Posted Jul 25, 2020 02:40 PM
    @Sharee Anderson,
    Try adding Read and Write privileges to Customizations and Read privileges to Solution and see if that does the job.
    I recall having the same issue at some point, and I believe those privileges were needed.
    Niels Lønberg
    Semco Maritime
