column filtering 'contains data' and 'contains no data'
  • 1.  column filtering 'contains data' and 'contains no data'
    Posted Jan 15, 2020 09:47 AM
    I am converting from the Legacy UI to the 'new' UI.  When in the new UI in a view and turn on filtering, I noticed the filtering does not have the option of 'contains data' and 'contains no data'.  Is there a parameter for this?  Has anyone else seen this issue?
    Thanks in advance!
    Kathy Anderson
    IT Project Mgr
    Milton CAT
    Londonderry NH
  • 2.  RE: column filtering 'contains data' and 'contains no data'
    Posted Jan 15, 2020 03:52 PM
    I see what you mean!  I just tested and found that if you use the Contains operator and don't put a value, it will return only records where that field contains data - but that might not work well for all field types.  I guess our only work around for now is to use Advanced Find for this type of filter criteria.
  • 3.  RE: column filtering 'contains data' and 'contains no data'
    Posted Jan 15, 2020 04:39 PM
    I have also noticed the lack of a Does Not Contain filter. I've gotten around it by sorting by the column I need to filter. All records where there is no value for that field are displayed at the top of the grid.
    Luke Palmer
    bpha Limited
    Bedford
  • 4.  RE: column filtering 'contains data' and 'contains no data'
    Posted Jan 16, 2020 04:11 AM
    UCI Views are a bit behind Classic.
    Also missing is Lookups: Filter by specific XXX
    Hopefully 2020 W1 will address these.
  • 5.  RE: column filtering 'contains data' and 'contains no data'
    Posted Feb 13, 2020 09:36 AM
    They listened!  I applied the 2020 wave 1 update to one of my sandboxes and I was just testing something and needed to filter an Accounts view when I noticed the new behavior.
    Instead of the little funnel icon we have in each column, we now have a little drop-down arrow to sort or filter - when you select filter, you have all the usual options we have in the classic interface.
  • 6.  RE: column filtering 'contains data' and 'contains no data'
    Posted Feb 13, 2020 10:38 AM
    Woo hoo!
  • 7.  RE: column filtering 'contains data' and 'contains no data'
    Posted Feb 13, 2020 10:51 AM
    @Donal McCarthy thanks for uploading that image....for some reason, when I try to upload a picture, nothing happens and when I tried to paste a snip, it thinks forever and nothing happens so I gave up! ​
  • 8.  RE: column filtering 'contains data' and 'contains no data'
    Posted Feb 13, 2020 10:56 AM
    @Jill Vazquez - you're welcome! I just grab with Snaggit and paste it into the dialog.​
  • 9.  RE: column filtering 'contains data' and 'contains no data'
    Posted Feb 14, 2020 11:36 AM
    Excellent news, thanks for sharing @Jill Vazquez.
    Engineer
