Scanned Business Card Image
  • 1.  Scanned Business Card Image
    Posted Mar 30, 2020 04:54 PM
    I'm testing out the business card scanning feature of the 2020 wave 1 release.  I have everything setup per the instructions, i have the system setting to retain the scanned image turned on and everything is working except being able to view the saved image.  Once i perform the scan and the fields populate, i can see the image, once i save and refresh the page the image is gone.
    Has anyone else been able to see the card image after a save and page refresh?
    any help is appreciated,
    Jim Corriveau
    A.W. Chesterton Company
    Groveland MA
  • 2.  RE: Scanned Business Card Image
    Posted Apr 06, 2020 06:42 AM
    Hi Jim,
    You know what, I have also faced this same issue recently and resolved it using below tricks/tweaks.
    First of all below are the prerequisites of using Business card scanner in Model driver app/UCI application.
    1. User must have Sales Enterprise License
    2. User must be assigned security 'common data service user'
      • Note if user = System admin then above role assignment is not needed
    Make sure you meet above prerequisites and now regarding the issue you are facing, from 1 of the Microsoft's official documentation on Business card setup I have found that I was missing 'Cleaned Image' property setup. This property must be set to single line/multi line text field through which you are scanning Business card. Example – if you have utilized OOB field of Business card scan then set it to 'businesscard'.
    Here is the documentation which I had referred to – https://docs.microsoft.com/en-us/ai-builder/business-card-reader-component-model-driven
    This answer is provided by Kishan Modha, Software Engineer, Dynamics CRM, Synoptek
    Nandita Nityanandam
    Marketing Head
    Synoptek
    Oakbrook Terrace IL
  • 3.  RE: Scanned Business Card Image
    Posted Apr 06, 2020 11:37 AM
    Nandita,
    That did it.  I had to put BusinessCard (multiple) in both the cleaned image and default image, but after that it appears to work fine.  Thanks for the help.
    Thank you,
    Jim Corriveau
    Groveland MA
