Webhook and Plugin in Dynamics are reacting to things that happen inside the system, so they would be rather used to send the data to en external API.
As Nicholas says, you should look at Virtual entities or build an html web resource which gets the data on load via JavaScript.
Zarko Radevic
Dynamics CRM Programmer
Digitale Medier 1881 AS
Sent: Sep 16, 2019 12:45 PM
Subject: Dynamics 365 – Model driven Apps
I have a 3rd Party Web API and want to display the API data in the Model Driven App. Is it possible to do the same using webhook or plugin and what will the approach for the same.
#CRM2016#PowerApps#CRM2016 #Focus-D365UG/CRMUG
Charles Nadar
Willis Towers Watson
