Ribbon Workbench Hide/Show Buttons on Boolean Fields
  • 1.  Ribbon Workbench Hide/Show Buttons on Boolean Fields
    Posted Nov 06, 2019 11:11 AM
    I couldn't easily find an answer to this question, so after some experimenting, I thought it would be appropriate to share what I've found should anyone follow after me.
    The use case was to show/hide buttons on a ribbon based upon a boolean field value.  Since you can represent a boolean field value with 1/0, yes/no, and true/false it wasn't immediately obvious to me which one the Ribbon Workbench would take as an input.  Turns out the Ribbon Workbench only recognizes the values of true/false when you're working with Display/Enable rules.  Hopefully that helps someone else down the road.
    #CustomerEngagement #Admin​​​​
    Jonathan Blackham
  • 2.  RE: Ribbon Workbench Hide/Show Buttons on Boolean Fields
    Posted Nov 07, 2019 06:38 AM
    Hi Jonathan,
    That is correct. Ribbon Workbench uses true/false for display/enable rules. Please ensure that the file in which the JavaScript function is written is part of the library of the form.
    Nikhil Rajendran
    Microsoft Dynamics CRM Developer
    Aha Apps
    Glen Allen VA
