Transition to UI Gap Analysis
  • 1.  Transition to UI Gap Analysis
    Posted Feb 14, 2020 02:45 PM
    Hi all, I'm working on a gap analysis on transitioning from 'classic' d365 to a domain-driven app using the new unified interface. We have a testing environment set up already, however I am hitting a roadblock. I'm hoping someone can provide some useful tools or tips on analyzing what it will take to transition smoothly from classic to UI. Some specifics are typescript validation, third party solution readiness, and any other areas you all may think are worth looking into. Thanks!
    Benjamin Patterson
    Defenders
    Indianapolis IN
  • 2.  RE: Transition to UI Gap Analysis
    Posted Feb 14, 2020 02:56 PM
    Hi Benjamin,
    You may want to check out Solution Checker from Power Apps. You can run the checker in make.powerapps.com. Make sure to select your environment on the top right of the screen. Once you open your solution, Solution Checker button will be available for you on the top menu bar.
    It can give you the information on issues in your solution and can start estimating how much effort your team needs to do from the list.
    Here is a simple step on how to use it. I hope by now, you have started playing around the new developer portal.
    https://learntoinspire.ca/2020/01/18/leveraging-the-power-of-solution-checker/
    I hope this helps.
    Cheers,
    Cristall
    Cristall Amurao
    Tala Dynamics
    North York
