daily check resulting
  • 1.  daily check resulting
    Hi all, can anyone suggest a good solution to the following;
    We need a daily check of a date field on a custom entity to see if it is within 6 months of today, if it is and the business process flow(BPF) is at stage 4 then update BPF to stage 5.​
    Thanks in advance.
    Ben Fisher
    Associate Technician
    Southampton
  • 2.  RE: daily check resulting
    Ben
    You might want to consider using Power Automate because of the recurrence aspect of your scenario and use the Recurrence trigger to schedule it. Elaiza Benitez has a really good post here on how to move stages on a BPF​ using Power Automate. Since your condition is checking whether the Active Stage is within 6 months, you will have to calculate  the difference between "Active Stage Started On" date and utcNow(). The way I've calculated difference in days in flow since there's no Datediff function is by using the Compose Action and the ticks() function as shown below. The last compose action contains difference between today and Active Stage Start date, so you can use that as the as your condition, instead of the Switch statement she uses in her blog post.
    The Expressions in each of the Compose actions are as follows:
    ticks(body('Get_record')?['activestagestartedon'])
    ticks(utcNow())
    div(sub(outputs('CurrentTIme'),outputs('ActiveStageDate')),864000000000)
    Edrei Mpanduki
    Technical Analyst
    Scottsdale AZ
