  • 1.  Removing CRM Plugin Steps
    Hi CRM UG,
    When I remove a plugin step, I remove the SDK message from the solution at the same time. But it seems I have to remove it manually from all the the environments before releasing through the pipeline. Is there anyway that I can avoid this manual pre-deployment step for removing a plugin step?
    Thank you in advance for the suggestions,
    Junbin Duan
    Senior Application Developer
    Ottawa ON
