Thank you everyone for reaching out and the feedback.
Andy, Mark can confirm but SQL4CDS should do the same as accessing via T-SQL in SSMS. Within SQL4CDS you can enable the T-SQL endpoint to use that if desired.
Mark,
My user is a system admin in the environment so it shouldn't be permission related. Also, I found that using SELECT COUNT(1) and SELECT COUNT(*) returned the same results so I used COUNT(1) on my subsequent queries.
The the job has completed but there are still some interesting outcomes. Bulk Deletion shows there were 12,685,775 deleted, way more than the 13-11k returned in the SQL4CDS query. I would see thousands added to the deletion total before seeing it drop by 1 or 2 in the SQL query.
Additionally, if I query in SQL4CDS now I show 5,323 records still meeting my criteria. If I run a bulk delete with that criteria it shows the 5,323 as deleted but re-querying after the deletion once again shows the 5,323. They are reported as deleted but never are.
When building the Bulk Deletion job I select the entity "Email Messages", not sure if that plays into a difference with the "email" table queried in SQL??
Scott Florance
Sent: Aug 14, 2020 11:31 AM
Subject: Bulk Record Deletion of Emails vs SQL for CDS Results
@Mark Carrington here posting under another account as the forums seem to be broken for me at the moment.
@Scott Florance, apologies for the delay, if the forums were working better I'd have responded to this a week ago. Presumably by now your job has finished so there's not much we'll actually be able to see. My best guess on the reason for the low numbers coming from your SQL 4 CDS queries though are permissions - do you have rights to see all the emails?
I'd also have been interested to see some different ways of getting the results - SELECT COUNT(1) isn't something I've optimised for so far, though this will be in the next release. SELECT COUNT(*) will use some more efficient ways of running the query, and while the results should be the same it's possible there's a bug in there somewhere.
Matt Beard
Senior Software Engineer
Data8
Sent: Aug 13, 2020 05:35 AM
@Mark Carrington (author of SQL 4 CDS) might have some input here?
Jonas Rapp
MVP
Sweden
Sent: Aug 05, 2020 10:06 AM
Hello Everyone,
Presently, database capacity is over limit for a client's tenant and it appears that the main culprit is that someone created Test from a full copy of Production. There are a large number of emails that come in to queues for this client and we have identified the ActivityPointerBase as a table of concern. I am looking to clear historical emails out of Test to free up space.
In doing so I am running the Bulk Record Deletion. I also ran SQL for CDS to understand how many records should be getting removed and get an idea of how long it might take. Unfortunately, something appear to be odd and I am hoping that someone in the community might be able to shed some light on this.
My deletion query is for email messages created on or before 8/31/2019. On Monday ~600,000 had been deleted and SQL for CDS was showing ~13,000 emails remaining.
What would be the reason for this to have such different numbers?
Scott
Scott Florance
