Rollup for related records of same entity type?
  • 1.  Rollup for related records of same entity type?
    Posted May 28, 2020 06:01 PM
    Dynamics 365 provides rollup fields on records in related entities. Example: Count number of Open Opportunities for an Account.
    However, can you rollup how many records are related to a record when it's the same entity type?
    Example: You need the total number of Contacts that each Contact is related to get an idea of how big their "personal network" is.
    When you go to define a rollup field, you're limited to selecting other related entities; you can't select the same entity.
    Allison Briden
    Energy Trust of Oregon
    Portland OR
  • 2.  RE: Rollup for related records of same entity type?
    Posted May 29, 2020 05:18 AM
    Yes, this is possible. You can either set up a hierarchical relationship between contacts and then choose the Use Hierarchy option in the rollup, or if you use the standard parentcustomerid field then you can select "Contacts (Company Name)" as the related entity
    Mark Carrington
    Chief Technologist
    Data8
    Chester
  • 3.  RE: Rollup for related records of same entity type?
    Posted May 29, 2020 02:50 PM
    Lovely! I overlooked the Hierarchy = Yes setting and that does give me exactly what I needed.
    Thank you, @Mark Carrington !​
    Allison Briden
    Portland OR
