Format date to be long date system wide
  • 1.  Format date to be long date system wide
    Posted Apr 03, 2020 10:24 AM
    Is there a way to format the system wide date to be for example April 3, 2020 instead of MM/dd/YYYY?
    I can only find where you can save it as date only or date time.
    Our end goal is to have the date formatting that way in our Word Templates.
    Thank you for your help.  I appreciate it!
    Karen Bebow
    Information Systems Manager
    Powell Fabrication & Mfg LLC
    St. Louis MI
  • 2.  RE: Format date to be long date system wide
    Posted Apr 06, 2020 08:39 AM
    Karen,
    I am so used to using my DocumentsCorePack add-on features to do this, that I had to double-check the delivered Word formatting options.  But you should be able to format your Word template Date Format by highlighting the date field on your template, and then navigating in Word to Insert >> Date & Time to open the different available date format options
    mscrm-addons.com
    Atlanta GA
    770 781 8260 Cell
  • 3.  RE: Format date to be long date system wide
    Posted Apr 15, 2020 11:18 AM
    Oh my, Patrick...I was so fixated on finding this in the system, that it never occurred to me to format it in Word (blushing.)  Thank you!
    Karen Bebow
    St. Louis MI
  • 4.  RE: Format date to be long date system wide
    Posted Apr 07, 2020 03:43 AM
    Hi Karen,
    You can change the date format in the System Settings. Go to the Formats tab, then Customize... then select your short date and/or long date format, similar to the attached screenshot.
    You may have to get users to log out or do a Ctrl+F5 refresh before they see the new format.
    Best regards,
    Andrew.
    Andrew Bibby
    Dynamics 365 Project Adviser & Microsoft MVP
    Evesham, UK
  • 5.  RE: Format date to be long date system wide
    Posted Apr 15, 2020 11:16 AM
    Thanks, Andrew.  I appreciate it!
    Karen Bebow
    St. Louis MI
  • 6.  RE: Format date to be long date system wide
    Posted 21 days ago
    Yes, we can connect an email to multiple entities in CRM? For instance, if we've an electronic mail to numerous human beings inside one agency that works after getting some training from fintexec academy. Can we attached that electronic mail to the account, all the character contacts, and possibility?
    wish ter
    loster
