Hi Nils,
our users also requested this function and I also didn't like the idea to code something.
However it seems that it is not fully achievable. However here is what I did:
1.) Create an old-school workflow, important part here is that I add the word COPY to a text-field that is also shown in subgrids etc., that way the users can easily identify the copied record (because: opening the copied record will not work without coding)
2.) Install the 'SmartButton'-solution from Develop1
3.) Open XRM Toolbox and then the RibbonWorkbench, create a new 'SmartButton' with one click and assigning the workflow
4.) For added user acceptance you can place the button in multiple locations: on subgrids, in associated record views, directly in a record
Our users can now mark an Opp in the subgrid of an account (they do not open it), click on Copy and will get a new Opp at the top of the subgrid with the added word COPY. They then change that Opp and of course also delete the word COPY from the text-field.
Unfortunately it is not possible to copy any related records using workflows.
Johannes
Johannes Henkel
Company
Sent: May 14, 2019 02:57 PM
Subject: Clone/copy Dynamics 365 record without saving it
I'm looking for a way to easily clone/copy a current record in Dynamics 365.
I have already tested some third-party solutions, like Dynamics Clone Pro and Click2Clone but they don't really work they I hoped the would as the save the record when it is cloned.
The functionality I'm looking for is like the one, that is available through @Natraj Yegnaraman's Chrome Extension, Level up for Dynamics CRM/365 'Clone Record'. However, I would like to make this functionality available for the users from within Dynamics 365 and not through a browser extension - as they can't install that.
The 'Clone Record' copies the fields of a current form to a new form, that opens in a new tab. The record isn't saved, so business rules are enforced which is important in my case.
Does anyone know of any tools that can do that, where it is also possible to define which attributes to clone/copy? Or if there are no such tools, would it be possible to create a custom button through @Scott Durow's Workbench Ribbon which runs a bookmarklet similar to the one that is used in the Level Up extension (or similar to these bookmarklets)?
