Unable to use Xpertdocs/Smartflows following MS update
  • 1.  Unable to use Xpertdocs/Smartflows following MS update
    Posted Nov 05, 2019 03:31 AM
    Hi, just want to know if anyone else is unable to use Xpertdocs/Smartflows following the weekends MS update.
    Case is logged with Xpertdocs who are working to resolve it but we use it for all of our event docs and is really affecting the day job, so interested to see if we are the only ones experiencing this issue.
    Error messages are:.
    "configuration is null" or "one of the scripts for this record has caused an error"
    Thanks in advance
    Sophie Marsh
    Campden BRI
    Chipping Campden
  • 2.  RE: Unable to use Xpertdocs/Smartflows following MS update
    Posted Nov 06, 2019 04:49 AM
    Dear Sophie
    Thank you very much for your question. We have picked up the issue instantly and have already found the root cause.
    Microsoft has updated some Dynamics 365 servers last weekend to version 9.1.0.1x. which causes the buttons of Xpertdoc Smart Flows not to load properly anymore. It appears a lot of third party add-ons were impacted by this.
    The way enable rules on commands in custom solutions are evaluated is changed, hereby caching results more aggressively, resulting in not rechecking the access that is needed when displaying buttons.
    We have sent out the new solution files to all customers to be able to update. So if you haven't done yet, please do via: https://kb.xpertdoc.com/pages/viewpage.action?pageId=43843597 . The issue should be resolved and everything should be working fine.
    Should there be any other questions, do not hesitate in reaching out.
    Thanks and best of luck.
    Kind regards
    Jochen
    Customer Success Manager Europe Xpertdoc<o:p></o:p>
    Jochen Heirman
    Xpertdoc
  • 3.  RE: Unable to use Xpertdocs/Smartflows following MS update
    Posted Nov 08, 2019 06:34 AM
    Thank you for the quick response, our suppliers were able to work with you and installed the solution so by close of business on Monday we were able to run Smartflows.
    Sophie Marsh
    Campden BRI
    Chipping Campden
