Multi-select field reporting in Power BI
  • 1.  Multi-select field reporting in Power BI
    Is there a way to make Power BI report separate results lines on a multi-select field?
    Example
    D365 Account entity with a multi select field  for "States involved in"
    The field data will look something like:
    Name                    Statesinvolved in
    Test Account         1; 5, 7, 10, 20    (the option set values)
    I want a result set that looks like this:
    Name                StatesInvolvedin
    Test Account      1
    Test Account       5
    Test Account       7
    Test Account       10
    Test Account       20
    Katie Warner
    Comagine Health
    Las Vegas NV
  • 2.  RE: Multi-select field reporting in Power BI
    Hi Katie,
    By using the new feature of the Power BI you can multi-select data element on visuals, you can now select more than one data point in Power BI Desktop report page, and highlight the results across the visuals on the page. To multi-select data points in visuals, simply use CTRL+Click to select multiple data points. See below screen capture for multiple data points select on visual(multi-select):
    Please let me know if you have any questions/concerns.
    Jay
    Jay Buddhdev
    Regina SK Canada
  • 3.  RE: Multi-select field reporting in Power BI
    Edited by Mike Hammons 10 days ago
    Hi Katie,
    Yes, this is possible in Power BI. Using Power Query after that values are imported, split the column that has the comma separated values, then unpivot the other columns. Here is a short gif that walks through the steps.
    Power BI split multiselect tableMight need to click the image to see the animation.
    Mike
    Mike Hammons
    AKA Enterprise Solutions
    Woodstock GA
