I feel like I finally got somewhere with a basic Flow / Power Automate routine. This was especially easy to accomplish as a Dynamics 365 workflow, but there will be a time when we can't use this. I have several recurring email workflows, and the first one I tackled is the weekly summary of new Dynamics 365 accounts. Here is what I did - I am sure there are other ways to accomplish this, and feedback is encouraged. Here is how I did it.
Of course, sending emails from Power Automate is among the easier tasks. The main challenge I had to overcome was including a clickable link to the record in the HTML table.
Result
Routine
The Filter Query uses the formatDateTime() expression
formatDateTime(body('Get_past_time'),'yyyy-MM-dd')
The Created On expression is as follows:
converttimezone(item()?['createdon'],'Dateline Standard Time','Central Standard Time','MM/dd/yyyy')
Then get your own profile (if this is a subscription to go to multiple users, you will need to do something else).
Then send an email. Embed whichever fields from your profile, contextual language, and CSS (for the table) that you desire. For the table itself, do not just use the dynamic field from the Create HTML table. Use this instead:
replace(replace(body('Create_HTML_table'), '<', '<'), '>', '>')
This will ensure that you get usable links, rather than full-text HTML code.
#PowerAutomate(Flow)
#Workflow #Admin
Adam Posegate
Fox Valley Technical College
Appleton WI
