Error Winning Quote but Only When Opportunity Has A Specific Value
  • 1.  Error Winning Quote but Only When Opportunity Has A Specific Value
    Posted Mar 31, 2020 01:26 AM
    I have some custom JavaScript that will update quote line item fields, win the quote, and then win the opportunity. It works well except when the opportunity has a custom picklist field with a value of 961150000.
    The message sent to Dynamics is:
      "Status": 4,
      "QuoteClose": {
        "subject": "Won Quote",
        "quoteid@odata.bind": "/quotes(ec3a757d-c272-ea11-a811-000d3a3b36cc)"
    The response is:
        "error": {
            "code""0x80040265",
            "message""The Opportunity has Type = Quote and Category = Estimate and cannot be closed as Won.",
            "innererror": {
                "type""System.ServiceModel.FaultException`1[[Microsoft.Xrm.Sdk.OrganizationServiceFault, Microsoft.Xrm.Sdk, Version=9.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]",
                "stacktrace""   at Microsoft.Crm.Extensibility.OrganizationSdkServiceInternal.Execute(OrganizationRequest request, InvocationContext invocationContext, CallerOriginToken callerOriginToken, WebServiceType serviceType, Boolean checkAdminMode, ExecutionContext executionContext, Dictionary`2 optionalParameters)\r\n   at Microsoft.Crm.Extensibility.OData.CrmODataExecutionContext.Execute(OrganizationRequest request, ExecutionContext executionContext)\r\n   at Microsoft.Crm.Extensibility.OData.CrmODataServiceDataProvider.ExecuteOperation(CrmODataExecutionContext context, EdmOperation edmOperation, Dictionary`2 parameters, Dictionary`2 boundParameters)\r\n   at Microsoft.Crm.Extensibility.OData.ActionController.ProcessOperationRequest(String operationName, Dictionary`2 operationParameters, EntityReference entityReference, String boundEntityName, String boundEntityType)\r\n   at Microsoft.Crm.Extensibility.OData.ActionController.<>c__DisplayClass9_0.<PostUnboundAction>b__0()\r\n   at Microsoft.PowerApps.CoreFramework.ActivityLoggerExtensions.Execute[TResult](ILogger logger, EventId eventId, ActivityType activityType, Func`1 func, IEnumerable`1 additionalCustomProperties)\r\n   at Microsoft.Xrm.Telemetry.XrmTelemetryExtensions.Execute[TResult](ILogger logger, XrmTelemetryActivityType activityType, Func`1 func)\r\n   at lambda_method(Closure , Object , Object[] )\r\n   at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)\r\n   at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary`2 arguments, CancellationToken cancellationToken)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()"
    The error message makes me believe that the exception is being thrown by custom code associated with the picklist field.
    I have searched all of the custom code that I have access to.
    I have checked all of the dependencies of that particular field on the opportunity and disabled all of the processes associated with it.
    I have also disabled all plugin steps associated with both the quote and the opportunity but still I get the error. There are no plugin steps associated with the win message of a quote.
    I can use Postman to pass the win quote message and the quote is won without error.
    Has anyone seen a similar error?
    Can anyone suggest a different place to look for the code that would cause this error?
    #Technical​​
    Scott Golightly
    Senior Developer
    JourneyTEAM
    Draper UT
  • 2.  RE: Error Winning Quote but Only When Opportunity Has A Specific Value
    Posted Apr 01, 2020 09:16 AM
    Hi Scott,
    I have had customers create synchronous workflows that prevent an opportunity from closing unless a field is a certain value e.g. progressed to a certain stage. I know you said you disabled processes that showed dependencies on that field, but possibly revisit your synchronous Opportunity workflows.
    Scott Florance
  • 3.  RE: Error Winning Quote but Only When Opportunity Has A Specific Value
    Posted Apr 03, 2020 04:14 PM
    I thought I had disabled all of the workflows but apparently I either missed one or I forgot to publish or something else because after going back to the workflows we were able to find one that was causing the issue. That workflow is now disabled.
    Scott Golightly
    Senior Developer
    JourneyTEAM
    Draper UT
