When you start a template from D365, you have a blank word doc - you can actually paste the content from your exiting document instead of building it from scratch and then adjust it as needed to remove static content and replace it with field content in the Developer Tab. You don't have to stay in your developer tab - you can use all the formatting techniques you would in a normal word doc.
I did a word template with a repeating table in it a while back. After pasting the form created by a business user, I removed all but 2 rows from their table - I left the header row and the first row of data. then, I went to each field in the first data row and replaced the value with an XML field. Then I set that row to repeating.
Sent: Feb 24, 2020 04:11 PM
Subject: Create Repeating Table For A Template Document
Thank you both your replies! I have the relationships figured out but where I am running into trouble is actually formatting the information into a table that looks similar to the one in my attachment (see new). ie: how to create headers and format columns within the Repeating Table.
Do I have to use Design Mode?
Gabriella Simpson
OpenTech Alliance
Phoenix
Sent: Feb 24, 2020 03:25 PM
Gabriella, attached is a screenshot to build on Jill's answer. Make sure the N:1 relationship is included when you begin the template document, otherwise the related entity will not be available at the end of your primary entity XML fields. Also, your screenshot looks pretty ambitious. What entity will the template associate with?
Michael Atwood
Wasmer, Schroeder & Co.
Naples FL
Sent: Feb 24, 2020 01:12 PM
My name is Gabriella, I am new to the Sales Enablement community and SE role within my organization. One of my tasks is to complete a Quote Template for our BDMs to help streamline their quote > order > docusign process. I have the XML mapping all figured out but am having a hard time configuring a Repeating Table for multiple product lines.
Does anyone know of any resources or can point me in the right direction? I greatly appreciate your assistance!
Gabriella Simpson
OpenTech Alliance
Phoenix
