Contacts being automatically created by SYSTEM user
  • 1.  Contacts being automatically created by SYSTEM user
    Posted Mar 04, 2019 12:09 PM
    Hi all,
    I'm hoping someone can help me resolve an issue we have with contact records being automatically created.
    We are on Dynamics 365 Online v9 and using Server-Side Sync and App for Outlook (and previously the Outlook Client add-in).
    We aren't using Automatic Record Creation and Update Rules.
    I believe we've always had this problem but its gotten progressively worse where we are getting anywhere from 50-300 contacts automatically created each month.
    The contacts are being created and owned by the SYSTEM user as a result of an email being received in one of our queues.
    3 big problems with this is that the contacts aren't attached to an account, they sit at root level and they are normally from spam senders.
    I can't find anything obvious in the System Settings under the Email or Outlook tabs.
    Anyone know what setting(s) might be behind this or know of a way to mitigate the problem?
    Thanks in advance,
    #Admin
  • 2.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 04, 2019 02:31 PM
    I had a similar issue and I had to work with Microsoft support to begin solving this issue.
    They had me download the EWSEditor to find the email that had been created in CRM.
    EwsEditor 1.20 released.
    I was able to get the details of the message from this.
    They found that there was another internal mailbox that was forwarding messages to a mailbox that I had set up a queue against.  We removed that forward to solve this issue - but then it happened again on some unrelated mailboxes. The EWSEditor didn't really help me as much I need so I still would need MS Support if I want to clean up these additional mailboxes.
  • 3.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 04, 2019 03:12 PM
    I ran into this recently as well.  One other thing to check is the indivudual user Personal options for automatically creating contacts.  You can see this option by going to your personal options, email tab, there is an option to 'automatically create records' on that page.  Anything created there has the 'SYSTEM' user as the created by.
    You can use the XRmToolbox plugin 'User Settings Utility' to find users that have that option set.
    Good luck!
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
    Tallahassee TN
  • 4.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 05, 2019 02:54 AM
    Using the XRM User Settings Utility, I've reset it to the below for all enabled users multiple times, but Contact record being created by System still keeps on happening for me with one user. What's worse - it creates dupes in the Contacts entity - despite there being a rule against this.
  • 5.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 04, 2019 04:31 PM
    @Mark Aston - I would second what @Chris Harrington posted. Using the XrmToolBox "User Settings Utility" would be the way to go. ​​
  • 6.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 05, 2019 06:55 AM
    If the User Setting isn't working for you (we had a similar issue) you can create a Workflow that runs on Contact create, checks the Owner of the record, and immediately inactivates it. There will still be "bad" data in the system but at least it will be hidden from the majority of users and processes.
    Meghan Deaver
    Devon PA
  • 7.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 05, 2019 01:20 PM
    Great, thanks @Chris Harrington, @Donal McCarthy and @Aaron Back, MCSE.  I've updated the users settings in XRM ToolBox.  There's a handful of users where I get the below error and it won't save the changes.  Have you seen this before?
    I wasn't sure whether to amend the user settings for users generated by the system that have an administrative licence or our service account.  I'm tempted to leave them alone but grateful for advice.
    @Meghan Deaver thats a really good idea to set up a workflow, i'll looking into creating that.​
  • 8.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 05, 2019 06:09 PM
    Hi Mark
    There are a serious of settings which are set globally on an organisation within Dynamics 365.
    AutoCreateContactOnPromote is your setting, by default this is set to true and hence the automatic creation of a contact record
    See the article:
    https://support.microsoft.com/en-gb/help/2691237/orgdborgsettings-tool-for-microsoft-dynamics-crm
    Do you have a sandbox instance it would be worth trying this out in a sandbox environment.
    Abdul Majid
    Abdul Majid
    Westwood Software Limited
  • 9.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 08, 2019 04:06 AM
    Hi @Abdul Majid, thanks for the info on AutoCreateContactOnPromote.  As I've changed all the users personal settings using XRM ToolBox, would this setting still something I should change?  Will it affect contacts created by the SYSTEM user which is a user I can't access via XRM ToolBox.
    I finished deleted contacts with no business value and moving those contacts to the correct account yesterday afternoon.  By the time i'd left there were 3 new contacts created by SYSTEM.  One for for a noreply email and the other 2 were Microsoft Exchange undeliverables.  Sounds like this might be to do with what @Travis Judd and @Ben Trappel​​ experienced and probably need to get Microsoft involved to diagnose.
  • 10.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 08, 2019 05:32 AM
    Edited by Abdul Majid Mar 08, 2019 05:36 AM
    Mark
    This is a setting that is not available via the Dynamics OOB interface.
    There is a Dynamics 365 solution that is available to help you change this setting globally for the organisation.
    Once the solution has been imported, it provides its own interface that you may use set the Organisation Setting : AutoCreateContactOnPromote.
    The setting is on be default, which you would have to turn off, to prevent contacts being created automatically.
    I can give you a demo, as I have done it on my organisation.
    If you feel more comfortable putting a ticket into MS that would be fine too.
    Abdul Majid
  • 11.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 08, 2019 09:28 AM
    Just as an fyi,
    I spent about 8 hours with Microsoft and the exchange team to track down the exact mailbox that was causing the issue.  The entire process with Microsoft started on 3/26/2018 and ended 5/1/2018 when we were able to finally locate the issue.
    First was locating the email messages origin (trekstorehopperscrossing) which is an email that dynamics doesn't watch/
    Then figuring out which queue was creating the message (customerservice_australia)
    This request from our enterprise systems global admin ended up resolving the issue.
    Perhaps this will save you some time if you can figure out these things and see if forwarding is turned on.  Interested to know if this fixes it or if it was something else.
  • 12.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 08, 2019 09:45 AM
    Turning this flag off AutoCreateContactOnPromote, will capture all.
    I had the email coming into a queue, I switch off the switch AutoCreateContactOnPromote and contacts were no longer being created.
    This is a techy solution.
    But your welcome to double check this setting with Microsoft.
    Abdul Majid
  • 13.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 12, 2019 01:55 PM
    Did you manage to get to a solution?
    Abdul Majid
  • 14.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 14, 2019 01:35 PM
    Hi @Abdul Majid, i'll be going ahead with installing OrgDbOrgSettings (although I need approval first) into our Sandbox before deploying to Production.  Is GitHub (https://github.com/seanmcne/OrgDbOrgSettings)​ the best place to get the managed solution .zip?
  • 15.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 14, 2019 01:45 PM
    Edited by Abdul Majid Mar 14, 2019 01:51 PM
    HI @Mark Aston,
    If you scroll down on this page, their is a link to the releases which is the following:
    https://github.com/seanmcne/OrgDbOrgSettings/releases
    Its the release solution you need to get.
    OrgDbOrgSettings
    Its a managed solution so you will be able to remove it completely after you are done with it.
    So the idea behind installing the solution is so you may admin these settings. Please only edit what you need to "AutoCreateContactOnPromote" there is a link to the description of other settings you may see within the tool here > https://support.microsoft.com/en-gb/help/2691237/orgdborgsettings-tool-for-microsoft-dynamics-crm
    Microsoft remove preview
    This site uses cookies for analytics, personalized content and ads. By continuing to browse this site, you agree to this use.
    View this on Microsoft >
    Abdul Majid
  • 16.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 15, 2019 09:32 AM
    Thank you @Abdul Majid, I notice the file name has 8.0 in it.  ​We're on Dynamics 365 Online v9.1.  Do you happen to know if it is compatible with v9?
  • 17.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 15, 2019 09:39 AM
    Edited by Abdul Majid Mar 15, 2019 09:40 AM
    It works in 9.
    I have it installed on 9.
    Editor
    Abdul Majid
  • 18.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 15, 2019 09:58 AM
    Great!  Thanks for the quick reply @Abdul Majid
  • 19.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 26, 2019 04:23 AM
    How did you get on?
    Abdul Majid
  • 20.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 26, 2019 08:11 AM
    Hi @Abdul Majid, i installed the managed OrgDBOrgSettings ​solution into our Production environment yesterday evening and changed the AutoCreateContactOnPromote setting to False.  We've had no new contacts created by SYSTEM so far but I will keep on eye on over the rest of the week.  Thanks for your help with investigating this.
  • 21.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 27, 2019 06:50 AM
    Hi all,
    Not sure if this is related to what i've been doing in this thread (using XRMToolBox to update user settings and updated global setting in OrgDBOrgSettings) but users have noticed that their emails are now automatically being tracked.  This includes internal and external emails.  Will need to do some serious investigation on this but if anyone can think of anything obvious that I might have accidentally updated then let me know.
  • 22.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 27, 2019 07:58 AM
    HI @Mark Aston
    When you say automatically being tracked? Do you mean they are appearing within Dynamics?
    The only way I would have thought they can appear within Dynamics is if all the users mailboxes within Dynamics was synced. Did you TEST & Enable the mailboxes by any chance for the users or on the Email Configuration. As that would start syncing users emails to Dynamics.
    Abdul Majid
    Abdul Majid
  • 23.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 27, 2019 11:00 AM
    Hi @Abdul Majid, thanks for the quick reply.  Yes, the emails are appearing within Dynamics.  We had a problem a few weeks ago where emails weren't coming into a queue.  We raised a Microsoft support call and as part of their investigation they did test and enable all our users' mailboxes.
    I'm surprised that this would mean that their emails start getting tracked in Dynamics.  I'm starting to think this might be related to amending everyone's personal settings via XRMToolBox to only track Email messages from CRM Leads, Contacts and Accounts instead of Email messages in response to CRM email (which is what we had before).
    What way would you advise to disable emails from automatically being tracked.  Those that use App for Outlook need an enabled mailbox.
  • 24.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 27, 2019 11:47 AM
    OK.
    If e-mails are not coming into a queue then ONLY the queue mailbox should have had its email approved and the TEST and Enabled.
    There was no need to do this at parent level, doing at parent level has Approved and TEST & Enabled all of your CRM users mailboxes associated to the Server Profile.
    I am thinking, the best answer is go back to Microsoft and ask them why they did it - may be there was a misunderstanding somewhere.
    Abdul Majid
  • 25.  RE: Contacts being automatically created by SYSTEM user
    Posted Mar 07, 2019 12:56 AM
    Hi Mark, I recently had the same problem and found that the contact was created based on an email sent to a Shared Mailbox which was attached to a Queue.
    Ben Trappel
    RDWA
