Hi Kyle,
when I understand you correct you use the standard email templates within CRM. Now I can only tell you how you do it in CRM onprem but it still should be similar in Online.
Go to Settings / Templates / Email Templates and select the template you want to change.
Click into the body where you want to place the first name. Click on Insert/Update in the menu. In the pop up click on "Add" and now you should be able to select different entities (the entity selected for the template and the N:1 related entities like contact, user and account maybe others in your case).
Click on contact and select the FirstName. Now you should have a yellow marked field in your template. It has to stay yellow otherwise the link to the database is removed.
I hope this is what you are looking for.
Axel Girgensohn
Dynamics CRM Specialist
Aller Media AB
Sent: Sep 16, 2020 03:22 PM
Subject: Related Entity Field on Email Template
Is there a way to pull in a field from a related entity into an email template? For example, I have an email template for the Quote entity. In the body of the email I want to be able to pull in just the first name of the customer contact on the quote record. The quote record contains the contact's full name, so I was trying to figure out a way to pull in just the first name of the contact record related to the quote record. Is this possible without any kind of custom code?
Kyle Polliard
Manager, Sales & Marketing
Allegheny Technologies, Inc.
Natrona Heights
