Marketing app - Marketing Pages - change default page/web templates
  • 1.  Marketing app - Marketing Pages - change default page/web templates
    Hi
    I'm trying to create new page/web templates for Marketing Pages in the Marketing App.
    I can created the new page/web templates.
    However in the Marketing Pages, I cannot select my new page/web templates and it places in defaults. I can edit the defaults, but i require multiple page/web templates.
    Please can someone tell me how to select my new page/web templates.
    I'm getting pretty desperate at the moment.
    This seems such a simple thing to do, and I cannot figure it out.
    Lee Chamberlain
    Myjex
  • 2.  RE: Marketing app - Marketing Pages - change default page/web templates
    Hello Lee
    Could you add a little more detail on what you're trying to achieve?
    When you create a new marketing page, by default, it will be hosted on the portal which comes with the marketing app (Event portal in your screen shot above)
    The URL for the Marketing page you have created in on the Summary tab:
    Regards
    Deborah
    Deborah Pitt
    The Pensions Regulator
    Brighton
  • 3.  RE: Marketing app - Marketing Pages - change default page/web templates
    Hi
    I've several different headers and footers with complicated html, css and Javascript in them.
    I need to use different headers/footers at different times.
    Simply adding them to a marketing template isn't suitable for what I'm trying to do, so selecting a different page/web template as required seems like the most sensible solution.
    Lee Chamberlain
    Myjex
  • 4.  RE: Marketing app - Marketing Pages - change default page/web templates
    Hello Lee
    Sounds like you need the edit the pages directly in the Portal.
    Go to Power Apps
    Then select Apps. Click on the ellipsis next to the portal and then select edit:
    This will give you access to both the pages and the templates:
    Regards
    Deborah
    #Marketing
    Deborah Pitt
    Brighton
  • 5.  RE: Marketing app - Marketing Pages - change default page/web templates
    Thanks Deborah
     I can edit the header and footer, but as I said in my first email, I require multiple, and cannot select anything but the defaults as the fields are locked.
    Lee Chamberlain
    Myjex
