Hi Laura
Can you give a bit more detail re the records causing the problem. Are they a lookup table (entity). This is a trap to be wary of.
We use the Data Transporter from the XRMToolBox - works a treat. Use the Filter Option (top right). Get your FetchXML from Advanced Find for the records you need.
Be careful not to create duplicates and if you do - work out how your are going to handle them.
i'm sure someone in your User should also be able to help you otherwise reach out here again. Teams is good if you really help.
Regards
Peter Hale
Dynamics Admin/Dev
Naish Pty Ltd
Ormiston QLD Australia
Peter Hale
Naish Pty Ltd
Sent: Feb 22, 2021 09:34 PM
Subject: Migrate/Copy records from Sandbox to Production
We built some views that reference particular records (and the GUID of those records) and we moved the views from sandbox to production. Rather than update over 100 views, we would like to migrate these 5 records from sandbox to production so the views work. I googled and found a way to do it, but it referenced using a power shell. Anyone know of an easy way to do this? Thank you! Laura
