Open Forum
Subject: Dynamics 2015 On-Premises slow in Internet Explorer
1.  Dynamics 2015 On-Premises slow in Internet Explorer
Posted 19 days ago
Hi everyone,
We started experiencing an issue recently and I am starting to spin my wheels.  Hopefully someone can point me in another direction.
What I Know:
- When loading entities in Internet Explorer 11, it is taking a long time to load sub-grids, the social pane, business process flow area, and other aspects of the page
    - By a long time I mean it takes over 20,000 ms, in other browsers it is taking 2,000 ms or less
- This is for any entity with any of those controls
- This does not occur in FireFox or Chrome
- We have 2015 On-Premises
What I have tried:
- Clearing IE cache & history
- Resetting IE via Internet Options
- Downgraded to IE 10
- Imaged a brand new machine with an older set of patches (approximately 2 - 3 months old) - Things work fine on IE in this machine
- Used Performance Center to compare load times (pretty much tells me what I already know)
What I assume:
- This is not a network nor server issue, otherwise other browsers would be affected.  Am I correct in assuming this?
- It is most likely a Windows client workstation update causing the issue, but haven't been able to prove it yet
- I would think if I downgraded (uninstalled/reinstalled) to IE 10 then it's not an IE update causing the issue
Has anyone else run into this or have any guesses as to what may be going on?  Thanks in advance for any help!
Ben Edgren
Business Analyst - Enterprise Systems
Employee Benefits Corporation
Madison WI
2.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 19 days ago
I don't know if this is the full answer, but IE11 is simply older, slower technology than the browsers you're testing against.  It will load CRM pages slower than Chrome, Firefox, or Edge.  There likely is something else going on as well, for as big a difference as you're talking about, but don't expect it to ever look like Chrome's performance.
Wayne Walton
CRM Practice Lead
eBECS
Atlanta GA
3.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
We experienced the same thing about six months ago. One day users started complaining that things were really slow. I googled everything to find an answer. I rolled back patches and uninstalled extensions and add-ons. Nothing worked. It was particularly slow loading sub-grids (up to 7 seconds to finally load the screen!)
I even worked with our CRM partner and they said it was on our end.
We finally switched everyone over to Chrome. No more complaints!
Paul Luhn
IT Administrator
JRCERT
Chicago IL
4.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
Do you have any 3rd party solutions installed?  We had one, also while on CRM 2015, that did this exact thing.
Also, though it shouldn't matter that much per browser I wouldn't think, can you clarify whether turbo forms are on or off?
Adam Robinson
Director of Information Technology
Industrial Air Centers
Jeffersonville IN
5.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
To add to @Adam Robinson's post, check in your System Settings/General tab to see if the Legacy Forms setting needs to be toggled.
Aaron Back, MCP
Sr. Microsoft Dynamics 365 (CRM) Consultant
6.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
Ben
Did you profile the performance in IE11? That would tell you whatever is holding things up with BIG RED blocks.
https://msdn.microsoft.com/en-us/library/dn255005(v=vs.85).aspx
Rex Tan
Programmer
The Davey Tree Expert Company
Kent OH
7.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
We are also on CRM 2015 on-prem. I get a lot of end users complaining about CRM lag when they use IE. Just to add confirmation to the discussion: once they change to Chrome/Firefox, speeds increase substantially. I advise following the instructions in this link to compare performance in different browsers. The first step listed in this article I have used several times to troubleshoot performance. IE consistently performs poorer than Chrome.
http://www.powerobjects.com/2015/10/19/performance-tools-built-into-crm/
Philip Frederick
Schaeffer's Research Inc.
Blue Ash OH
8.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
Maybe you can "collapse" any subgrids/sections that don't need to render each time the page opens. If the user wants those to open they can "expand" the view/subgrid/charts.   Just show the data that is always needed.
Tim Dailey
Starkey
Eden Prairie MN
9.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 18 days ago
Thanks for all of the replies!  I should have included our version in the original post:  7.0.2.53 and so we do not have the Legacy Forms option yet.
And I do understand and agree that Chrome and Firefox will be slightly faster than IE.  However a difference of 20 seconds cannot be account for by browser differences, and is not acceptable to the people using the system every day...or so they've told me, multiple times, the past few days :D
I'm working with our IT Operations team to look into any Group Policy rules that may be affecting this.  I would also look into our solutions, however I have not installed any new solutions recently and it is affecting our Out of the Box instance (absolutely no customization nor solutions have been added to that instance) and our development instance.
I sort of ruled out a Windows Server Update as I feel if it was a server issue it would affect all browsers.
I have tried rolling back Windows workstation/client Updates on my machine which has had no effect yet, but am halfheartedly continuing down that path with IT Ops.
Nothing appears off with the diagnostics test (attached), and I am looking into profiling the JavaScript right now.
Ben Edgren
Madison WI
10.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Ben
Try using fiddler. The built-in crm test is kind of "misleading" as it only test the best case scenario (no plugins, rules and etc.)
Running fiddler on a user's machine while loading crm will definitely expose any latency issues.
https://community.dynamics.com/crm/b/develop1/archive/2014/04/15/fiddler2-the-tool-that-gives-you-superpowers-part-1
Rex Tan
Programmer
Kent OH
11.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Thanks Rex!
It looks like "LookupMruWebService.asmx" and "MessageBar.asmx" are the common culprits with very long load times.  Other .asmx, .aspx, and .ashx resources take quite a bit of time as well.  Could a .NET framework update cause an issue like this?
Another weird thing I noticed, the IE log has around 175 lines/results to it while the Chrome session log only has around 25 lines/results.
Ben Edgren
Madison WI
12.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
You're welcome.
It looks like this is a documented issue.
https://social.microsoft.com/Forums/en-US/0d0d47a7-917a-4c2d-9b5f-55816d957637/crm-web-service-lookupmruwebserviceasmx-taking-long-execution-time?forum=crm
https://community.dynamics.com/crm/f/117/t/139033
Each browser has its own ways of logging things, even worse is that each browser has its own way of interpreting js (i.e. tabs is not an array in ie but is in chrome).
You can try changing your chrome settings.
https://developers.google.com/web/tools/chrome-devtools/console/
Rex Tan
Programmer
Kent OH
13.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
That's kind of what I was worried about: I had seen that first link you shared but the second appears to confirm it a bit more.  Just seems odd that it was working great for 5+ years in IE, then seemingly out of nowhere the performance takes a dive.  I would also think this would be a larger issue among the community.  There has to have been plenty of businesses using IE and On-Prem 2015; and still probably enough around to have see it more in various forums.
I'll keep plugging away and if anything helps I'll be sure to come back and update this post.
Ben Edgren
Madison WI
14.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Edited by Rex Tan 11 days ago
Ben
Have you tried rebooting the server? I have heard of where patches will cause crm server performance to degrade but are resolved after a reboot.
I am suggesting this due to the fact that the problematic code belongs to Microsoft and there is really nothing we can do about those.
Rex Tan
Programmer
Kent OH
15.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Yep, that was actually one of the first things we did (checked the application and sql servers, rebooted them, checked our out-of-the-box CRM instance running on an entirely different server, etc.)
KB4041681 was our salvation.  It was released on 10/10/17 and has worked for every user I tested with so far.
There is a specific line in there about fixing the form submission in Internet Explorer, I'm pretty sure that hits the nail on the head.
This updated took us from IE "update version" 11.0.46 (which is when the problem started) to 11.0.47 in case anyone else is interested or having this issue.
Ben Edgren
Madison WI
16.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 9 days ago
Great! and thanks for the info.
Rex Tan
Programmer
Kent OH
17.  RE: Dynamics 2015 On-Premises slow in Internet Explorer
Posted 6 days ago
We just downloaded the latest update you mentioned and it worked for us as well. It removed the slowness of loading sub-grids in particular. However, since we have switched over to Chrome and everyone is happy, we will probably stay there.
Paul Luhn
IT Administrator
JRCERT
Chicago IL
