  • 1.  Affordable and Best PST Splitter software to Split PST File Free
    PST files are used by Outlook to store emails, contacts, calendars, and other data. It also stores every item in a separate file. It also happens that sometimes users can have PST files of Gigabytes in size. So, the question is – How to split PST file free? And, if you are trying to split PST files, then the next question is that is there any best & free PST splitter software?
     So, In this thread, we will fix users' questions using Manual techniques as well as the DRS PST Splitter tool.
    Manual Techniques to Split PST file free
    In this section, we will provide you with free manual techniques to split PST files free. Follow the method mentioned below:
    Method 1: Manage Large PST file Using Move to Folder Option
    Here is another way to split the oversize PST file of Outlook. Below is the stage that will guide you to break the large Outlook PST file.
    1. Start Outlook, navigate to File>Info>Tools>Clean up Old Items.
    Select Archive this folder and all subfolders options and provide the date to archive the older items and hit on Browse button to provide the location path to save the archive file.
    Using this technique, you can easily reduce the PST file size and save the older data to them where you want location, and use it whenever needed.
    Method 2: Archive Wizard to Reduce PST file
    Archive wizard is another manual technique by which you can split PST files free.
    • Start Microsoft Outlook press on the File>Info>Cleanup Tools>Archive and follow the second option given above in method 2.
    Drawbacks of Manual techniques
    • It is a very time-consuming process
    • Need to technical knowledge
    • data loss or data corruption
    These are some possible limitations of manual techniques for split PST file free, In these circumstances, You can opt Professional method.
    Professional Method to Split large PST File Free
    DRS PST Splitter software is a reliable tool that makes it extremely easy to split Outlook PST into smaller files without damaging or altering original file data. The tool can split files of any existing version and size. The user can also specify factors such as date, time, particular email & password for splitting the files which further increases the application's utility & usability. The tool supports all Windows OS and can be operated with ease in any Windows version.
    This utility is designed to help you split your large PST files into smaller ones. In case you have a large file and want to save it as a backup, or if you have several small PST files but now need to combine them into a single one, this tool will do the job for you.
    Conclusion
    In the above writeup, We are fixing users' queries on how to Split PST File in Outlook 2016, 2013, 2010, 2007? We provided you with the 2 manual methods as well as the expert method. You can perform using the best and expert method.
    Hope this writing helps you.
    Chandrabhan Gupta
    DRS Softech
  • 2.  RE: Affordable and Best PST Splitter software to Split PST File Free
    Edited by alice murphy 14 days ago
    It is very much necessary to split large size PST files into small files because when you split large size PST files then it ensures no corruption in your PST . Along with this , you can improve your Outlook performance by breaking your large size PST files into small file. However , if you want to know about different techniques through which you can split your large size PST files then you can refer to this blog which describes different ways of how to reduce size of PST file. Here, you will learn about a manual technique that is a free DIY approach and the other approach is an automated technique which is more easy and reliable technique. If you want to proceed with manual method then you must have  proper technical skill otherwise you can opt for the professional solution.
    alice murphy
    DRS
    California
  • 3.  RE: Affordable and Best PST Splitter software to Split PST File Free
    To Split Outlook PST file into multiple small PST, Use Split Outlook PST Tool. It is an independent single wizard utility, which easily segments multiple PST files at a time without any error. It always gives 100% secure results. Any technical or non-technical user can easily operate the software because it has an attractive and user-friendly GUI interface. This software breaks the PST file in both ANSI and UNICODE format. Download the free demo version of the software.
    Visit here for more info:- https://www.softakensoftware.com/split-outlook-pst.html
    Roger Patel
    Reuitenhenry
    Orlando
  • 4.  RE: Affordable and Best PST Splitter software to Split PST File Free
    Try MailsDaddy PST Split Tool to divide large PST files into small pieces by date, size, email-id, and folder. It breaks PST files in all Version of Windows OS and MS Outlook. The PST Splitter easily splits large PST files without any damaging data. The split PST tool automatically split up your large PST file including emails, contacts, calendars, journals, notes, tasks, etc. into smaller PST files. It performs without installation and configuration of MS-Outlook and is also capable in ANSI and also UNICODE formats.
    Somendra Singh
    MailsDaddy
