  • 1.  Best MBOX to PST Free Converter Tool to convert MBOX to PST Online
    Edited by Chandrabhan Gupta 15 days ago
    If you are searching for the best MBOX to PST free converter tool to convert MBOX to PST Online, then you are in the right place. Here we provide you with a complete solution for MBOX to PST Conversion.
    An MBOX file stands for Mac Mail mailbox. It is an email client that was created by Apple for their Mac OS X operating system. These files are quite large in size and can be opened in the Thunderbird client. But the recent versions of Thunderbird do not support these files. The best way to open these files in the Windows operating system is to convert them to another format. They can be converted to. PST files could be easily opened using the MS Outlook client.
    How to convert MBOX to PST Online Manually?
    You can follow the manual tricks provided to convert MBOX to PST Online. Here are some manual techniques for the migration of MBOX to PST.
    # Use Email clients to convert MBOX to PST Online.
    MBOX file is also used by Apple mail, but in order to convert MBOX to PST online processing is done by various steps which are very tedious in nature.
    1.    Processing using Apple Mail.
    • Next, Run Apple mail on your laptop.
    • Press on File and pick importing mailboxes from the file menu.
    • Now, select the MBOX file's source and hit proceed
    • After the process of importing the files gets completed, choose the MBOX file from the browse location menu, then tap on done.
       Note:- All the files that needed to be converted should be there.
    2.    Processing using Eudora
    •  First of all, rename your information and add a .mbox  extension to the imported MBOX file.
    •  This should migrate the Filename.MBX to the location where all the root folder of Eudora lies (C:\Documents and Settings\Application\Data\Qualcomm\Eudora).
    •   Then, Start the application and run Filename.MBX file.
    3.    Processing using Outlook Express
    • Open Outlook Express and select the application and go to File>Import>Messages.
    • Select from the drop-down menu and tap on the Next option.
    • Presently, go to the location where you have saved yourself.MBX file and tap OK.
    • Proceed to the next steps to finish the import process and check if the files have been converted successfully.
    4.    Processing using Outlook.
    •  To export files, open MS Outlook and hit on the file option.
    •  Pick the Import/Export option and tap on the Import option.
    • Then, Pick import from another file and folder option and hit on the Next.
    •   On the follow-up page select Import internet mail and address and press on the Next.
    •  In this process choose Outlook Express 4.x, 5.x, 6.x or window mail option and proceed.
    •   At last, select the DBX file to finally import it to the Outlook application.
    Convert MBOX to PST Online Using Professional Method
    The manual method does not allow exporting MBOX files to Outlook PST format with attachments, so if you need to convert MBOX to PST online along with all attachments like image, video, doc, PDF, and all. So, I highly suggested opting for Direct solutions i.e, DRS MBOX to PST Converter tool that can easily migrate your multiple MBOX files into PST format in a single attempt. The software is designed in a user interface that both technical and non-technical users operate without any technical expertise.  It is a very successful and trusty software.
    know more visit here:- https://www.data-recovery-solutions.com/mbox-file-converter.php
    Conclusion
    We hope you enjoyed our blog about how to convert MBOX to PST Online. We provide manual solutions but manual techniques are a more complex and time-consuming process, So highly recommend the DRS MBOX File Converter tool that can easily convert your MBOX file into PST format.
    Chandrabhan Gupta
    DRS Softech
  • 2.  RE: Best MBOX to PST Free Converter Tool to convert MBOX to PST Online
    With the help of MBOX to PST Converter software allows users to convert unlimited MBOX files. It successfully exports MBOX to MS Outlook and converts MBOX to PST with text, attachments, folders, and subfolders, Message properties like to, from, cc, bcc, sent/received dates and times, Calendar items, Task items, Encrypted email, and attachments. Refer:- https://www.softakensoftware.com/mbox-to-outlook-converter.html
    Alan Vince
    Softaken Software
  • 3.  RE: Best MBOX to PST Free Converter Tool to convert MBOX to PST Online
    Posted 5 days ago
    MBOX to PST converter tool is a complete tool, which allow users to save MBOX file to PST format without alteration in data structure. This incredible tool converts MBOX emails to many formats like- RTF, HTML, Office 365, MSG, PDF, etc., without missing single information. It supports each edition of Windows OS and MS Outlook. The tool has easy and fast conversion techniques so anyone can do it without take technical person help. The tool also provide 24*7 technical support and a free trial version of tool.
    For more details, visit here: www.datarepairtools.com/mbox-to-pst-converter.html
    Angus Brown
    DataRepairTools
