Outlook PST Repair Tool
  • 1.  Outlook PST Repair Tool
    Posted Jun 01, 2021 07:18 AM
    Edited by Shikha Lal Jun 01, 2021 07:19 AM
    MailsDaddy Outlook PST Repair Tool helps in quick fixing of damaged Outlook PST data file into multiple formats. The deep scan each PST items to recovery them including all mails, notes, meetings,, journals, attachments, etc. Outlook PST Recovery also permits users to save the emails in MSG format, contacts into VCF and calendars in ICS files. The application also has the provision to split the large PST file into small data. User can use this highly effective solution in Windows operating system and repairs their Outlook PST data without any difficulty.
    Read  more: https://www.mailsdaddy.com/outlook-pst-repair/
    Shikha Lal
    Mailsdaddy Software
  • 2.  RE: Outlook PST Repair Tool
    Before using software, you can also repair your PST files manually, below I am sharing the step by step procedure:
    1. First it's important to find the location of SCANPST.EXE, depending on the version of MS Outlook
    2. To open the Outlook Inbox Repair tool double click on SCANPST.EXE.
    3. A new window opens i.e Inbox repair tool, click on Browse, and select the corrupted PST files.
    4. Click on the Start button to start the scanning process.
    5. You will get a message, once the file is scanned and then, click the Repair button.
    6. Depending on the size, the file will be repaired successfully.
    This process will always not be effective, as ScanPST.exe has some limitations as well. Try using a third-party tool like Stellar Repair for Outlook when the corruption is severe or you have a large/oversized PST file. This tool is mostly recommended by professionals of Microsoft and many IT admins.
    It has an easy user interface and can be compatible with most of the Outlook versions. Easy to install and with few clicks your PST will be back at your fingertips.
    Try using the free version here: https://www.stellarinfo.com/outlook-pst-file-recovery.php
    Emily Will
    +919654767489
    Gurgaon
  • 3.  RE: Outlook PST Repair Tool
    Posted 9 days ago
    Do you have a corrupted Outlook PST file and are searching for a solution to fix it. An excellent PST repair software developed by Shoviv software that known as Shoviv Outlook PST repair tool. The PST repair software is built with multiple user-centric features and easily scan and repair the corrupted PST data without changing data originality.
    Highlights:
    1. You can add multiple PST files of all sizes.
    2. The PST repair software is a fast & prompt way to repair corrupted Outlook PST data files.
    3. After recovered PST data, simply Exports them into MSG, HTML, EML, RTF, etc.
    4. Split option for large PST files in Shoviv Outlook PST repair tool.
    5. This PST repair software maintains folder hierarchy.
    6. PST files can be exported into Office 365, Live Exchange, Lotus Domino, and Novell GroupWise.
    7. Shoviv Outlook PST Repair tool supports all Outlook & Windows O.S.
    You should look at its free demo version, which will allow you to process the first fifty items per folder.
    For more info -  Outlook PST Repair Tool
    Albert Taylor
    Shoviv
