US - Florida CRM
Dynamics / Outlook Download Files
  • 1.  Dynamics / Outlook Download Files
    Posted Dec 29, 2014 08:30 AM
    This message has been cross posted to the following Discussions: Florida Regional Chapter and Open Forum .
    There are 2 files (amd64 and I386) that are available to download to setup Dynamics within Outlook.   I can't find any documentation that describes the instances when either of these 2 files should be used.    Does anyone have more information on this?
    I thought it had to do with the type of computer we were installing it on (amd processor vs intel) but that didn't seem to make a difference.
    Any input for this newbie would be appreciated.
    Mary Cunningham
    Comfort Systems USA
    Houston TX
  • 2.  RE: Dynamics / Outlook Download Files
    Posted Dec 30, 2014 09:51 AM
    Mary –
    You would probably get a better response if you posted this in the Open Forum, rather than the Florida regional forum.
    That said, if you're using the 32-bit version of Outlook, use the i386 version of the client.  If you have the 64-bit version of Outlook, use amd64.
    Karla Keeney
    IT Specialist/Trainer
    Resource Consulting Group
  • 3.  RE: Dynamics / Outlook Download Files
    Posted Dec 30, 2014 07:45 AM
    Mary -
    The amd64 is for a 64-bit machine and i386 is for a 32-bit machine.  If your machine is relatively new, chances are good it is a 64-bit unit.
    Thanks, Bob
    Sent from my Windows Phone 8
  • 4.  RE: Dynamics / Outlook Download Files
    Posted Dec 30, 2014 09:08 AM
    It depends on the version of Microsoft Outlook (Office) that you have installed.  If you are running Windows 64-bit but Office 32-bit, you will need to install the i386 (32-bit) Outlook Client.
    Tyler Sand
    Application Developer
    MarineMax
    Clearwater FL
  • 5.  RE: Dynamics / Outlook Download Files
    Posted Dec 30, 2014 08:29 AM
    Thanks Bob.   Does the version of MS Windows or MS Office suite installed on the computer have anything to with it?    I recently had an issue with a Dell 64-bit computer system where I was having an issue with the install using the amd64.   I switched to the I386 and it installed perfectly.    That is why I thought that maybe I was missing something with these files.
