D365 Licenses for non-Production Instances
  • 1.  D365 Licenses for non-Production Instances
    Posted Aug 22, 2018 01:36 PM
    In O365/D365 on line v9.0.... Is there a way to configure access for our Developers or external Consultants that will allow them access to only non-Production environments without consuming a D365 license?
    Thanks in advance,
    Jim
    Jim Corriveau
    A.W. Chesterton Company
    Groveland MA
  • 2.  RE: D365 Licenses for non-Production Instances
    Posted Aug 22, 2018 03:36 PM
    Since the license give access to all environments, we only give them a limited security role in the environment we want to allow them in and then give no security roles for the others - they can't access anything without a role.
  • 3.  RE: D365 Licenses for non-Production Instances
    Posted Aug 22, 2018 04:42 PM
    Hi Jim,
    You will need to consume either a full license for the developers/contractors access the non-production environments.  If you need to restrict their access to just the Non-production environments though I would take a look at using 0365 security groups to control which environment they can access.
    Cheers
    Todd.
    Crmug remove preview
    View this on Crmug >
    Todd Mercer
    Dynamics CRM Technical Lead
    MD Financial Management
    Ottawa ON
  • 4.  RE: D365 Licenses for non-Production Instances
    Posted Aug 23, 2018 06:25 AM
    Jill and Todd,
    Thanks for the help.  It seems like there should be an easier way.  Since production is copied to other non production instances it would be nice if i could set the security for production and all other instances at the production instance level then when production is copied the Users get the security assigned for that specific instance.
    Thanks again,
    Jim Corriveau
    Groveland MA
