Business Process Error - MetadataCache
  • 1.  Business Process Error - MetadataCache
    Posted Jan 10, 2019 05:28 AM
    Edited by Niels Lønberg Jan 10, 2019 05:28 AM
    I'm using the tool 'Set Process Stage' by @Pablo Peralta within the Dynamics 365 Workflow Tools (1.0.54.0) by @Demian Adolfo Raschkovan to update the Active Stage of a Business Process Flow in real-time. This is working fine in my development environment. However, I have now moved the solution to a new environment where I'm getting a Business Process Error related to MetadataCache.
    I'm not sure if it is an error caused by me somehow, the workflow tool or some bug in Dynamics 365.
    1. I have the same version of Dynamics 365 Workflow Tools (1.0.54.0) in both environments
    2. Both environments (Dynamics 365 Online) are running the same server version (9.1.0000.1118) and client version (1.3.948-181220-062045)
    3. I have tried creating a new Business Process Flow in the new environment and updating that using the workflow tool, but the result is the same
    I have pasted the error messages returned by D365 below. I am not getting much wiser be looking at them - but hopefully, some of you can :)
    Any input is appreciated.
    Error Message:
    The entity with a name = 'salesprocess' with namemapping = 'Logical' was not found in the MetadataCache. MetadataCacheDetails: ProviderType=Dynamic, StandardCache=True, IsLoadedInStagedContext = False, Timestamp=1545579, MinActiveRowVersion=1545579
    ErrorDetails.txt:
       at Microsoft.Crm.Extensibility.OrganizationSdkServiceInternal.CreateInternal(Entity entity, CorrelationToken correlationToken, CallerOriginToken callerOriginToken, WebServiceType serviceType, Boolean checkAdminMode, Dictionary`2 optionalParameters)
       at Microsoft.Crm.Extensibility.OData.CrmODataExecutionContext.CreateOrganizationResponse(Entity entity)
       at Microsoft.Crm.Extensibility.OData.CrmODataServiceDataProvider.CreateEdmEntity(CrmODataExecutionContext context, String edmEntityName, EdmEntityObject entityObject, Boolean isUpsert)
       at Microsoft.Crm.Extensibility.OData.EntityController.PostEntitySetImplementation(String& entitySetName, EdmEntityObject entityObject)
       at Microsoft.PowerApps.CoreFramework.ActivityLoggerExtensions.Execute[TResult](ILogger logger, EventId eventId, ActivityType activityType, Func`1 func, IEnumerable`1 additionalCustomProperties)
       at Microsoft.Xrm.Telemetry.XrmTelemetryExtensions.Execute[TResult](ILogger logger, XrmTelemetryActivityType activityType, Func`1 func)
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary`2 arguments, CancellationToken cancellationToken)
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()
    Activity Id: 6ae210c3-aa3c-4569-a63e-442f95e42149​
  • 2.  RE: Business Process Error - MetadataCache
    Posted Jan 10, 2019 05:47 AM
    I just tried to create a record using the Classic Interface (I'm using Unified Interface otherwise). Here I'm getting a bit more information from the error message - which seems to be related to the workflow tool:
    An unexpected error occurred from ISV code. (ErrorType = ClientError) Unexpected exception from plug-in (Execute):  msdyncrmWorkflowTools.Class.SetProcessStage: System.Security.SecurityException: Request for the permission of type 'System.Security.Permissions.SecurityPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.​
    Does anyone know what this means?
  • 3.  RE: Business Process Error - MetadataCache
    Posted Jan 13, 2019 02:08 AM
    Edited by Bhartendu Pandey Jan 13, 2019 02:08 AM
    Hello Niels,
    Yep the second error message tells us the exception is indeed coming in from the workflow tool . "An unexpected error occurred from ISV code"
    I guess somewhere it is failing to "have the permissions required by the platform to set a process stage" .
    However if you tried creating a record and you did not have the system admin security role then i would request you to check if the custom business process flow has the required permissions by checking under the Business Process Flow tab for that security role
    Bhartendu Pandey
    Willis Towers Watson
  • 4.  RE: Business Process Error - MetadataCache
    Posted Jan 14, 2019 01:57 AM
    @Bhartendu Pandey
    Thanks for your input. I'm testing this with the System Admin role, so I shouldn't be that which is stopping me.
    I'll keep digging to see if I can find a solution.
