How to delete managed fields where iscomponentdeletionenabled is false?
  • 1.  How to delete managed fields where iscomponentdeletionenabled is false?
    Posted Mar 29, 2019 02:39 PM
    ​​We have some custom fields that are now obsolete and I need to emove. We created these fields but they got included in a managed solution that ended up overwriting our development environment.
    There are no dependencies. When I try to delete the fields in the UI, I get an error RE:
    The 'Delete' operation on the current component(name='Attribute', id='27b59de5-6d13-43ac-a668-a3b79abefb4b') failed during managed property evaluation of condition: 'Managed Property Name: iscomponentdeletionenabled; Component Name: Attribute; '
    I tried the method of creating the Managed Solution and updating the Managed Solution to delete the field components, but they were not removed. Method here.
    I cannot find this attribute "iscomponentdeletionenabled" in the MetadataSchema in the database to be able to change it.
    Is there a way to find and edit the offending condition in the SQL database or the customizations.xml file to enable deletion of these obsolete fields?
    Allison Briden
    Energy Trust of Oregon
    Portland OR
