Switching Entity Ownership
  • 1.  Switching Entity Ownership
    Posted Sep 20, 2019 03:45 PM
    Is there a way to switch an entity ownership from organization to user/team without recreating the entity?
    Megan Crooks
  • 2.  RE: Switching Entity Ownership
    Posted Sep 20, 2019 03:53 PM
    I don't believe that is possible. In the past if I wanted that flexibility I would create an entity as user/team and simply Hide owner on all forms and views.
    Just in-case requirements change I can simply un-hide the owner.
    Krishna Jacques
    CRM Specialist
    Rumsey Electric Company
    conshohocken PA
  • 3.  RE: Switching Entity Ownership
    Posted Sep 23, 2019 01:55 AM
    Hi Megan
    In a word NO
    Recreate a new entity and then migrate the data – depending on relationships that will be easy or hard.
    The other way is easy – you just do what Krishna says.
    Pete
  • 4.  RE: Switching Entity Ownership
    Posted Sep 23, 2019 02:05 AM
    ​Hello Megan,
    There is a way to change the entity ownership by updating the XML of your solution file, but this is not supported. The steps are shown below. More information can be found on this blogpost: update entity ownership
    • You will need to create a solution containing your Entity that requires modifying ( I would include components as it makes for a much smoother import process)
    • Export your solution and store in a safe place
    • Export the same solution again
    • Find your solution and unpack the file using WinZip or something similar
    • Copy the Customization XML to the desktop
    • Open the File with either Visual Studio or you can even use Notepad
    • Follow the 3 steps below to edit the XML
    Rick Peters
    Rick Peters
    KPMG
    Hilversum
  • 5.  RE: Switching Entity Ownership
    Posted Sep 23, 2019 07:16 AM
    Hi Meghan,
    Is there a specific reason you need to switch the entity ownership?
    Nikhil Rajendran
    Aha Apps
    Glen Allen VA
  • 6.  RE: Switching Entity Ownership
    Posted Sep 23, 2019 08:20 AM
    Yes, the entity was incorrectly created as an ownership-organization, and there is a large amount of data and customization with the entity.  We have connected the entity to queue items, but we cannot route it (assign the "worked by") because there is no "ownerid" field (which comes with ownership - user/team).
    Thank you!​
    Lauren Palsgrove
  • 7.  RE: Switching Entity Ownership
    Posted Sep 23, 2019 10:51 AM
    Hi Megan.  I see you've posted this situation regarding the routing.  Without a major migration of the data to a new record, along with all the relationships, and customizations or the "unsupported change", create a bridge entity to use to route.  The bridge entity would have a 1 to 1 relationship with the Org owned entity.  You'd route the bridge and "drag" the org entity with the routing (in theory).
    Sanford Mosby
    Sr. Technical Consultant
    Dyn365Pros
    St. Louis MO
