Workflow Help - Time Consideration
  • 1.  Workflow Help - Time Consideration
    Posted Jan 21, 2019 10:31 PM
    I have a workflow that sends an email to customers when a Case is closed inviting them to take part in a Voice of Customer survey. Occasionally we close an old Case that triggers this email, which causes confusion for the customer. I need to add a check condition to the workflow that only allows it to trigger if the elapsed time between the Created On date is in the last 14 days. Can someone tell me if this Check Condition will accomplish this, or if I need to do something different:
    Case --> Modified On --> Is Less Than or Equal To --> Case-{14 Days After Created On}
    Nancy Peterson
    Senior Business Analyst
    Pitsco Education
    Pittsburg KS
  • 2.  RE: Workflow Help - Time Consideration
    Posted Jan 21, 2019 11:43 PM
    Nancy,
    That should resolve your issue. I don't think you need anything extra.
    Andrew Butenko
  • 3.  RE: Workflow Help - Time Consideration
    Posted Jan 22, 2019 08:25 AM
    Thanks, @Andrew Butenko. It's always nice to have someone confirm the logic!​
    Nancy Peterson
    Pitsco Education
    Pittsburg KS
  • 4.  RE: Workflow Help - Time Consideration
    Is there a way to write this to compare the Created On date for the Case to today's date? I thought we had this fixed, but customer service was cleaning up some inactive cases today and it started triggering VOC emails, even though the Case was closed more than 14 days after it was created.
    Nancy Peterson
    Pitsco Education
    Pittsburg KS
  • 5.  RE: Workflow Help - Time Consideration
    You can use the process execution time in a workflow to compare a date against the executing time of the workflow - could be of use?  This is effectively today's date, or 'now'.
    Andrew Bibby
    Evesham, United Kingdom
  • 6.  RE: Workflow Help - Time Consideration
    That's what I was looking for. I've created the Check Condition as follows:
    Case:Created On​ <= [14 Days Before Process-Execution Time]
    Thank you, @Andrew Bibby
    Nancy Peterson
    Pitsco Education
    Pittsburg KS
