Emailing HTML Templates with images and attachments from D365
  • 1.  Emailing HTML Templates with images and attachments from D365
    Posted Aug 06, 2019 10:51 AM
    Hi Folks,
    We've hit the limit I think of what we can do with the OOTB email templates. My sales team is looking send HTML email templates with images, etc and at times include attachments to email to their contacts.
    From best I can tell in using the OOTB email templates or Quick campaign to Email, it does appear to be possible.
    so hoping folks can point me in the right direction
    1. either there is a way to do it leveraging OOTB tools (i.e. With in D365 Customer Engagement)
    2. Is there another tool that can do the job easily and allow the easy management of the various templates in use.
      1. HTML driven templates, allowing the users to add attachments, and ideally have the email record sent, reside in D365 regarding the contact.
    Thanks for your input!
    Todd Mercer
    Dynamics CRM Technical Lead
    MD Financial Management
    Ottawa ON
  • 2.  RE: Emailing HTML Templates with images and attachments from D365
    Posted Aug 06, 2019 11:52 AM
    Edited by Tim Dailey Aug 06, 2019 11:53 AM
    Todd-
    I would recommend Power Mail Chimp (Power Objects) - the html template works really well (for entry level too)
    You will need a Mail chimp account but PMC handles the integration for you.
    https://www.powerobjects.com/powerpacks/powermailchimp/
    I use Click Dimensions, but I would not recommend it.
    Also, if using attachments, I recommend storing each attachment in Sharepoint and linking to them within the email templates vs. actual attached files (space saver)
    Tim Dailey
    Starkey Hearing Technologies
    Eden Prairie MN
  • 3.  RE: Emailing HTML Templates with images and attachments from D365
    Posted Aug 07, 2019 03:24 PM
    Afaik there is a new email editor in UI, however I'm not sure if that editor is used for templates as well or just for sending emails directly.
    https://community.dynamics.com/365/b/dynamics365enterprisecloudfronts/posts/dynamics-365-tip-sending-emails-using-unified-interface-853887768
    Sissy Bottcher
    StudyPortals
    San Diego CA
  • 4.  RE: Emailing HTML Templates with images and attachments from D365
    Posted Aug 08, 2019 03:01 AM
    As you are using Customer Engagement, you are probably entitled to a free instance of Dynamics Marketing with a minimum of 2k contacts.
    We've just installed in on our sandbox and will slowly be rolling it out and replace native email templates and our use of Constant Contact.
    Interestingly, when we installed it, we discovered we were entitled to 18k contacts. I queried this with support and was told the following:
    "Since your quota is tenant based and is multi Geo, It has license in each region, that is why you can see 2000 * 9 Geos contacts = 18000 contacts."
    BTW, in the interim, you can use the email client in the UCI and copy and paste the results into the email template window.
  • 5.  RE: Emailing HTML Templates with images and attachments from D365
    Posted Aug 12, 2019 09:25 PM
    Thanks everyone for the input. Given me a few leads to explore.
    Todd Mercer
    Ottawa ON
