Adam, I completely agree. I do not see how Flow will be able to replace native workflows because there are use-cases for synchronous workflows that Flow cannot do. I prefer to work with Azure LogicApps becuase it can do what Flow does for a fraction of the cost. When they advertise 2000 "runs", that is actually each step in the Flow that interacts with CRM, not a single execution of a Flow. For example, If you have a single Flow that has 10 action steps that access D365, then you have 10 runs each time you run that flow.
BroadPoint, Inc., Bethesda MD
Link with me!
https://www.linkedin.com/in/nelsonjohnson/------------------------------
Sent: Aug 05, 2019 09:56 AM
Subject: Workflows now suggesting I use Flow
This morning I started seeing this message when I edit workflows:
- Flows are owned by a user, while workflows can be set to any owner. I want the workflow to be run by a system user or user who initiated the workflow.
- Flows require syntax knowledge in order to accomplish the same action in a comparatively simple approach using dropdown selections.
- Flows do not "port" existing workflows. If I am using a plugin or workflow toolkit, it is prohibitive to attempt to recreate this using flow.
Flow was pitched as a "no cliff" approach to automation at the CRMUG Summit last October, with complete parity to workflows. As far as I can tell, the development of a more pleasing graphical interface was done without regard for the fact that actually using workflows is easier.
Adam Posegate
Fox Valley Technical College
Appleton WI
