Hi Marc, does the user who imported the leads have enough priviliges on the BPF? I don't know if you are using a standard or a custom BPF. On a custom BPF you sure have to give read and create privileges.
We create a lot of leads from a webform or from file by program. In both cases we connect a custom BPF to the lead by filling the processid field directly with the bpf-guid.
hopes this helps
Wim Krings
DevOps Engineer Dynamics 365
Apg
Heerlen
Sent: Mar 17, 2022 04:59 PM
Subject: Leads not associating with Lead BPF
We imported a number of lead throught the standard import wizzard. All the leads are visible and everything is fine except that none of them show the active BPF for leads. Any lead created manually shows the BPF no problem. Also we can manually associate the BPF with the leads but we should not have to do this.
Does anyone knows why the lead - bpf association doesn't trigger automatically when the lead is created via import?
Marc Longtin
Hilo Énergie
Montréal QC
