Outlook Client address not synching (CRM2013)
  • 1.  Outlook Client address not synching (CRM2013)
    Posted Dec 05, 2018 12:19 PM
    ​Hi
    When synching contacts from Outlook to CRM, the account name populates on the contact record in CRM, but the address does not. Does anyone have a solution for this?
    Jill
    Jill Miller
    ICM Inc
    Colwich KS
    Kansas City Chapter
  • 2.  RE: Outlook Client address not synching (CRM2013)
    Posted Dec 06, 2018 08:15 AM
    Hi Jill,
    If you have not already done so, you will want to make sure that CRM is setup to synchronize the fields.  You can do this from Settings -> Administration --> System Settings, then select the tab for Synchronization.  You'll get a pop-up that looks like this:
    CRM SystemSettings
    Once you click on the Synchronized Fields, it should pop up this view.  Select Contact from the drop down, and make sure you have the fields you want synchronized selected.
    SynchronizationFields
    Pheng Yang
    Edina Realty
    Edina MN
